Difference between MMC650 & MMC6500
I know one's a component but they are made exactly the same as far as material goes and the MMC6500 has a higher power rating. I just bought the MMC650 and you don't need a speaker with a power rating higher than the MMC650. A 125W RMS mid/high-range speaker inside a car is really overkill. The MMC650s are very loud at 50W RMS. What's the advantage of the MMC6500? They sound very similar, correct?
