how does one determine a ports hz?
joeaudio26
im purchased a well made hdf ported enclosure but my problem is matching a sub to it companies want to know whats the port tuned too? how does one know. This is the only info i have on the box.
http://www.circuitcity.com/ssm/Bass-Slammer-Single-Vented-Subwoofer-Enclosure-BS112V/sem/rpsm/oid/119723/catOid/-15481/rpem/ccd/productDetail.do
Whatsoever thy handfindeth to do, do it with thy might; for there is nor work, nor device, nor knowledge, nor wisdom, in the grave, whither thou goest.
Post edited by joeaudio26 on
this box is tuned to 38Hz. you just have to do some looking around on the web to find the full specs on the box. I just searched the model number, found a link to the manufacturers website and it came up with a spec sheet and it had it right there in front of me.2002 Chevrolet Tahoe Z71 4x4:
Kicker ZX250.2
Polk MMC6500
Pioneer TS-A1681R
Dual Kicker 05CVR124
X-File XR8002 -
Nice find tahoe..............HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
thanks bro2002 Chevrolet Tahoe Z71 4x4:
Kicker ZX250.2
Polk MMC6500
Pioneer TS-A1681R
X-File XR8002 -
2002tahoe wrote:this box is tuned to 38Hz. you just have to do some looking around on the web to find the full specs on the box. I just searched the number, found a link to the manufacturers website and it came up with a spec sheet and it had it right there in front of me.
thanks, Tahoe now i can make a choice in subs do you know of any subs that meet this enclosures requirement. Looking for a sub around 300 rms !:DWhatsoever thy handfindeth to do, do it with thy might; for there is nor work, nor device, nor knowledge, nor wisdom, in the grave, whither thou goest. -
honestly, i dont know how to match a sub to a box. you might want to send a message to exalted512 or macleod2002 Chevrolet Tahoe Z71 4x4:
Kicker ZX250.2
Polk MMC6500
Pioneer TS-A1681R
X-File XR8002 -
you could just change the port lenth and size to tune the box whatever hz range you are looking for.
itd be hard to extend the port though.
Really, you can put almost any sub in almost any enclosure. The trick is how you power it.
That being said, if you want to match a sub to go to your box, look up the volume of the box then look up the volume recommendations for various subs and pick the ones that closest match.
If the box is a little too big, you want to put a little less RMS power to the sub. If its a little small, you can put a little more power to the sub.
exhalted, not to look totally stupid, but i didn't notice his link. i wouldn't have even suggested changing the port.
