Ho wmuch power to RTI 10's or RTi 12's
Home Theatre
How many watts would you suggest to run the Rti 10's or RTI 12's?
Which Rotel amp or receiver would you suggest?
Everything I own burned in the fire!!!!!!!!!!
Post edited by Home Theatre on
for the 12's i would suggest the biggest amp you can find ( at least 300 watts of good power per channel). I wouldn't use a receiver with either of them.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture. -
So you would suggest a Outlaw or Rotel amp for them?Everything I own burned in the fire!!!!!!!!!!
I think you will get response on both. Personally I have never owned outlaw, but did own Rotel at one time and was satisified.Michael
NORTH of 60° -
Either one of those companies will do fine, just get at minimum 200wpc!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
So if I was to get a 500X2 Potel amp it would be overkill.Everything I own burned in the fire!!!!!!!!!!
NO!!!! There is no such thing as overkill when it comes to powering big speakers!!! Those RTI's will sing like canarys with all that power!
My speakers are being powered by 405wpc & they all love it & so do I!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
http://www.rotel.com/products/specs/rb1092.htm
Would this work for home theatre hooked up to a Denon 7.1 receiver?Everything I own burned in the fire!!!!!!!!!! -
Yes it will. And I personally preferred the RB1092 500wpc 2 channel over the 1077 100wpc 7 channel. Those extra 400 wpc made a BIG difference!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I have RTi10's and I'm getting the Outlaw 7700 delivered today. I can't wait to finally throw a little more power at them than what the receiver has been. After I purchased the 7700, I noticed some big power amps going for almost the same amount on Audiogon. Very tempting, but I'll stick with 200 wpc for now.
Outlaw and Rotel amp would be just fine. You might consider B&K amps. I found B&K calms down the silk tweeters a lot and make music more natural. Some members feel B&K's are to lean back amps. I found them to be very nice with Rtis series and you can listen to music for extended periods with less fatigue.
Gator
Theatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre -
Thanks for your help. One question I am thinking about buying a Outlaw 200X7 or Rotel 200X5 amp. Now I know this is perfect for the fronts, is this too much power going to the surrounds and center?Everything I own burned in the fire!!!!!!!!!!
Again, NO. ALL of my speakers all of which are 8ohms are being pushed with a405wpc 5 channel amp. The clarity that is now coming from ALL of them is simply outstanding!
Sunfire Cinema Grand Signature 5 ch. Amp, Polk RTA-8T Main Speakers, Boston 920 Center Channel, Polk FXi-3 Surround SpeakersMarantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
What if you have one speaker that is 6 ohms and ones thats is 8ohms?Everything I own burned in the fire!!!!!!!!!!
It's still fine!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
