Any Amp recommendations?
Phasearray
Phasearray Posts: 437
edited November 2006 in Electronics
I'm a noob to this.
I take Amps are what I place between the receiver and speaker to bring out their full potentials. Any good recommendations or some good read?
Receiver - Onkyo HT-R340
Front - Pioneer S-HF21
Center -Onkyo SKC-340C
Surround Back - Polk R15 <--Ticket to club polk
Subwoofer - Onkyo SKW-340
Post edited by Phasearray on
  • MikeC78
    MikeC78 Posts: 2,315
    Yes,
    The "SEARCH" feature in the upper right hand corner.
  • opus
    opus Posts: 1,252
    How about a little more info on what you have now and why you think you need an amp.
    The Flea rig
    Hitachi 50VG825 LCD
    Rotel RSP 1066 (pre) :)-flea market
    B&K St-202 (mains)-flea market
    Carver M 200t (x2) (center and surrounds)-flea market
    Blu-Ray..PS3 (dvd player)
    Polk RTA-11t-flea market
    LsiC, Fxi30's
    Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
    Behringer Feedback Destroyer
    -flea market
    AudioAlchemy DDE v1.0 DAC-flea market
    Cambridge Audio Azur 640 CDP-flea market
    Signal Cable and Kimber Kable
  • Phasearray
    I want to be able to run a pair of LSI25
  • janmike
    janmike Posts: 6,146
    Welcome to the forum. It's like purchasing anything else (car, boat, house, speakers....). What's the budget?
    Michael ;)
    NORTH of 60°
  • Phasearray
    hmmm I don't really know. It's hard to set a budget when I know so little about amps. All I know is my receiver will be inadequent to run a pair of LSI25. I can probably get a good deal on LSI for around 2k/pair.
    How guess an amp is the last piece of consideration I need for a system. Pair of LSI25 for 2k I think is pretty reasonable, but if it takes a thousand dollar amp to run them, then I might back down to some lesser speakers.
  • Shizelbs
    Shizelbs Posts: 7,433
    It won't take $1000 necessarily in an amp to run them, but you will likely find that you are going to want to spend more than the minimum to power them.
  • Phasearray
    sigh~
    I might have to ease off the LSI25. Amps to power something 4ohms are sure expensive ><
    tonyb Posts: 33,019
    Older carvers will work and can be had on the cheap pretty much anywhere.
    Good luck!
  • surfntomm
    surfntomm Posts: 185
    if you want a cheap solution you can get a pro amp which has tons of power and use your receiver as a pre. i got mine new for 200 on a clearance sale and it has 275 watts/ch in 4 ohms.
    ps ive heard lsi 15's are better? someone correct me if im wrong and you can definitely find cheaper than 2k for a pair of lsi25's if you search the used market (dont know if you are going used or not).
  • cfrizz
    cfrizz Posts: 13,415
    Cheap is not necessarily better. I wouldn't want to run my speakers off of an amplifier that is meant to run concert speakers! Home equipment for home gear!
    Just be patient, save more money & get what you really want! You will be truly satisfied without second thoughts later on!
  • MikeC78
    More expensive isn't necessarily better either.
    There are tons of people that use pro amps with good results. There is nothing wrong with it. Pro-amps IMO are the best kept secret in HT to get the added power you need.
    I've known and heard people on several forums that have done a double-blind test with very expensive amps and pro-amps and could not tell the difference.
    Mike
  • Ron Temple
    Ron Temple Posts: 3,212
    Mike
    ...and some claim the pro amps exceed some very high end gear. I was sure tempted based on some folks experience, but I wimped out on a used Carver TFM 35 ;) ...waiting shipment confirmation.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Phasearray
    Is Pro Amp a brand or a style of amplifiers?
  • Phasearray
    seesh most of these amps are about as efficient as CFA and TWTs. Never thought I would be considering running such a beast at home. I guess with winter coming its a good time to put a couple of 1kW amplifiers to warm the place up.
