Pre/Pro worth the dough??
Early B.
My Acurus 5-channel amp arrived today. I'm using my Pioneer receiver as a pre/pro. Is there a significant or subtle difference in moving into a pre/pro at this point? I figure a good used pre/pro will cost me $750 to $1,000 (for me, that's a huge investment). Here's the thing -- I have an extremely simple setup. The only things I have hooked up to my receiver are the pre-outs and sub, an S-video and RCA cables for the TV, and a digital cable for the DVD player. That's it.
So for my setup -- is a pre/pro worth the dough?
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
IMO, keep the Pioneer as a pre/pro. Use the money saved up to get a REAL HD DVD player!
I see you have an Oppo 970HD DVD player in your sig?? When did they start making those??
Mike -
MikeC78 wrote:I see you have an Oppo 970HD DVD player in your sig?? When did they start making those??
Mike
Mike,
That is the product number for the Oppo Universal SD DVD player. The HD following the 970 refers to the fact that the DVD player can upconvert to HD formats like 720p or 1080i.
http://www.amazon.com/OPPO-DV-970HD-Up-Converting-Universal-Player/dp/B000GT5FK0/sr=8-2/qid=1163189152/ref=pd_bbs_sr_2/103-4624683-3069454?ie=UTF8&s=electronicsHolydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
Holydoc wrote:Mike,
That is the product number for the Oppo Universal SD DVD player. The HD following the 970 does not mean High Definition.
:eek:
Thanks... I didn't know that?
Seems kinda misleading to me, what does the HD mean then?
Ok, you edited your post after I posted!
Mike -
Mike,
I edited my original post to be more explicit. Dang you quote fast!Holydoc (Home Theatre Lover)
I looked at your sig, how does that AAD blend in with the LSi's? If it doesn't then the money might be better spent there. I'd also put money down for HD-DVD player before a separate prepro like Mike suggested, unless you can offset the price by selling the Pioneer and buy used prepro.
Sami wrote:I looked at your sig, how does that AAD blend in with the LSi's?
The 9's arrive on Tuesday. I'll let ya know.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
