center channel
snow
what would make a good match center channel wise for sda srs 1.2tls ? THANKS IN ADVANCE SNOW
Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Post edited by snow on
A pair of CRS+s.
if you have the upgraded tweets, the LSi line is supposed to be a pretty good match.
if i hooked up a pair of crs speakers for a center wouldndt that represent a 3 ohm load? if so would that be a problem for a amp? REGARDS SNOWBobMcG wrote:A pair of CRS+s.Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
snow wrote:if i hooked up a pair of crs speakers for a center wouldn't that represent a 3 ohm load? if so would that be a problem for a amp? REGARDS SNOW
There are people who are doing it this way and it has been discussed a few of times. A quick search will turn up info on it. Here's a couple of links to the subject of using them as such.
http://www.polkaudio.com/forums/showthread.php?t=38939
http://www.polkaudio.com/forums/showthread.php?t=37675
If you're interested, Larry Chanin himself is a good source for info on how to do it right. -
ok great thanks. REGARDS SNOWBobMcG wrote:There are people who are doing it this way and it has been discussed a few of times. A quick search will turn up info on it. Here's a couple of links to the subject of using them as such.
If you're interested, Larry Chanin himself is a good source for info on how to do it right.Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
