Amplifiers
mauro_ferrante
mauro_ferrante Posts: 28
I'm sorry, may be I didn't express myself properly. English is not my maternal language, anyway this time I'll try to make myself clear.
Let's say I have a Denon A/V-1907 (85 Watts per channel max output) and a pair of LSi25 front speakers (about 200 watts continuous average output).
So the question is: the signal coming out from the A/V amplifier should be re-amplified before reaching the spekers?
Thanks,
Mauro.
Post edited by mauro_ferrante on
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited November 2006
    Are you asking if the speakers, themselves, amplify the signal?
    edit: Okay, you're asking if you need external amplification....
  • zombie boy 2000
    Unless your average listening levels are low and lower, I'd strongly advise you pick up an external amp. Otherwise, you'll probably end up damaging your speakers, and most certainly won't be getting the most out of them.
  • mauro_ferrante
    That's it. I want to know if I need external amplification.
  • mauro_ferrante
    OK thanks a lot.
  • Ricardo
    Ricardo Posts: 10,634
    Mauro,
    Your Denon will make the LSi25's sound, but it is definitely not enough power; those speakers are 4 ohm and need more power. If you just use the Denon, if you play at relatively high volume you might damage the speakers, and/or the Denon will probably go in protection mode.
    En otras palabras, necesitas un amplificador de mayor wattage....si usas solo el Denon puedes da
    SOPA
  • zombie boy 2000
  • Ricardo
    "In other words, you need an amplifier of higher wattage...if you use only the Denon you might damage the speakers at relatively high volume.
    I've been to Buenos Aires a couple of times....good beef (as in steak), beautiful women"
    You did pretty good :)
    SOPA
  • Schwingding
    Schwingding Posts: 363
    No. You do not NEED an amplifier. The sound coming out of your AVR is already amplified - to 85 watts per channel. However, if you wanted better sound and really wanted to make your speakers shine, you will buy some external amplifiers. When you do so, you do not re-amplify the signal, but rather connect those new amplifiers to the pre-amp outputs on your AVR.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • Ricardo
    True; you don't NEED it; just make sure you don't crank that Denon up......until you get an external amp.
    SOPA
  • zombie boy 2000
    Thanks... I knew "danar" right after I replied.
    parlantes = speakers... cool, I learned something new today:)
    sorry for the derail...
  • zombie boy 2000
    Yeah.. you don't need it. But it could be argued that you might get better sound out of more efficient (and probably, more affordable) speakers if only using the Denon, then attempting to power the LSi's with the same receiver...
  • mauro_ferrante
    Thanks everybody. I was just asking cause in the future I might buy others speakers and I wanted to know.
    My actual audio set is:
    Denon A/VR-1907 (85W x 7 channels)
    2 Monitor 60
    1 CS2
    1 PSW 12
    2 Monitor 30
    I think it sounds great. Do anyone of you think I should modifie something?
    (all the speakers are conected directly to the AVR).
    PS: veo que muchos de ustedes hablan muy bien el espa
  • schwarcw
    schwarcw Posts: 7,360
    Your welcome!
    Please post pictures of the Buenos Aires women
    Carl
