Center Channels
VR3
VR3 Posts: 29,392
edited November 2006 in Speakers
There is one thing in this hobby that just has remained odd to me.
There is alot of value in alot of monitor, tower, subwoofer speakers out there. When you start getting into surround and center channel speakers, all of this associated value is thrown out the window.
I have yet to understand how, for instance you could buy a pair of RT55i for 4-500 bucks, get four 6.5" midbasses, two 1" tweeters, and tons of cabinet, two crossovers for the cost of one CS400i which has two midbasses, one tweeter, one cabinet, one crossover. There is no way it cost Polk near as much as the 55i -
Is there any comments on this? Am I missing something...
Im looking at Tyler Acoustics, since I am getting a pair soon and the matching center for the line up is 1600 dollars. Now I am sure Ty can knock a good portion of that price off, but that is absolutely rediculous....
I dont get it...
Ill take a pair of monitors side by side anyday...
Post edited by VR3 on
  • cmy330go
    cmy330go Posts: 2,341
    I've often thought the same thing. Take my LSi-C for example. At the store I used to work at it was priced at $499. Yet LSi-9's and LSi-FX'x were only $449 each. Both no doubt have a higher production cost. The FX's have a larger more complicated cabinet with an extra tweeter, and a polarity switch. The 9's have a larger cabinet with the fancy side panels.
    I guess they figure they have you by the nuts, and that you have no choice but to buy the matching center.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • Early B.
    Early B. Posts: 7,900
    Yep, by the nuts...
    The center channel is the most important speaker in an HT setup, and manufacturers are aware of this, so they price them accordingly.
    Sid, make your own matching center channel for less than half the price of Tyler's. Check out Madisound's DIY section -- the Odin and Cygnet kits use the same drivers and crossover components as the Taylos.
    http://madisound.com/pdf/Kits/seaskits.pdf
    "God grooves with tubes."
  • Drumingman
    Drumingman Posts: 348
    With advances in sound technology, some of the ideas are not so great.
    Just because it's new, does not mean it's better, it's different.
    Downloading music vs. owning a CD is an example. Speaker systems are another example, yes the center channel is very important but I do not see these componets as good as the main speakers they are supposed to be working with. thats why I opt for 4 matching speakers across the front, especially for music. I also like multiple woofers as compared to a single stand alone unit. While there are a few subs that are very good, and I do mean a few, I would prefer to have at least two in my system.
    Bose is not not better, just different.
  • Drumingman
  • Holydoc
    Holydoc Posts: 1,048
    Unlike 2-channel systems where the right and left speaker are the "main speakers", with HT the center channel is the "main speaker" and all other speakers support it. HT requires a whole different way of thinking than a system built for music. 80% of the dialogue of the HT is coming from the center speaker and thus it must be the shining star of your HT setup.
    With that in mind, I agree and disagree with Sid (how is that for wishy-washy). If the center speaker is built with the idea that clarity in dialogue and integration of the soundstage is paramount, then the center speaker should be one (if not THE) most expensive speaker in the HT system. However as Sid eluded to, too many manufactorers just place the same drivers and crossovers as their R/L speakers in a different box and then jack up the price calling it a center channel. One way to tell a company that is serious about HT as compared to music reproduction is the company that takes the time, money, and resources to produce a center channel that works as the team leader rather than just one of the players.
    Holydoc (Home Theatre Lover)
    __________________________________________
    Panasonic -50PX600U 50" Plasma
    Onkyo -TX-NR901 Receiver
    Oppo -Oppo 980HD Universal DVD Player
    Outlaw -770 (7x200watt) Amplifier
    PolkAudio - RTi12 (Left and Right)
    PolkAudio - CSi5 (Center)
    PolkAudio - FXi3 (Back and Surround)
    SVS - PB-12/Plus (Subwoofer)
    Bluejean Cables - Interconnects
    Logitech Harmony 880 - Remote
  • Marcinko7
    Marcinko7 Posts: 121
    Holydoc,
    How does that Panny do for you, I'm looking to get that next.
    Denon 3806 Receiver
    Denon 3910 DVD
    Oppo BDP-83 Blu-Ray
    Outlaw 7500 300w x 5 @4 Ohms Amp
    58" Panasonic 800U 1080P Plasma TV
    SVS PB-12 Plus Sub
    Lsi25 Fronts-Cherry
    LsiC Center
    LsiFX Surrounds
    SMS-1 Velo Sub EQ
    PBJ Interconnects
    Blue Jeans Cables
    Everything was going just fine till my buddy poked the cop in the chest and said "did Andy give you your bullet today Barney?"
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Doesn't the center channel need extra magnetic shielding do it possible closeness to a TV? This may be why it cost more.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • disneyjoe7
    Also the R&D in building it, and people who buy one over a pair of speakers.
    I think it's the cost of doing business.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Holydoc
    Sorry about the derail...
    Marc,
    I love the 50" Plasma. However do not ask me to do a comparison with other plasmas since this is my first one. My decision to get this particular one was influenced greatly by all the reviews and the forums on AVS. As for its presentation of HD television (via Cox Cable 720p and 1080i), it is amazing to watch. You feel like you are looking out a window rather than watching a TV. Everything just seems 3D.
    I selected the 600u for its PiP, PC hook-up, and aesthetics (yes, I am weak that way). There is not one thing I would ask to be different about this TV.
  • MikeC78
    MikeC78 Posts: 2,315
    Kick A** Holydoc!!! Nice setup!:)
    Awesome plasma! I have last years commercial Panny PHD508UK, and loving it!:)
    Mike
  • Jose_L
    Jose_L Posts: 52
    The Odins and Tylers Acoustic's Linbrooks Sig Monitors use the same driver's but I'd doubt the crossover's are the same.
    Just go to htguide and check the Modula and NatalieP's crossovers. Same drivers but different networks...
    I had a complete SDA HT setup and I've moved to Ty's Linbrook system, big difference. Mainly clarity w/out harshness, well balanced. The only thing the SDA's do better is the soundstage.. :)
    here's my systems: http://www.relsyscon.com/projects.htm
    Regards,
    Jose
    Original SDA owner 1988 - 2006
    Tyler Linbrook owner 2006
  • Marcinko7
    Holydoc,
    I'm wanting the panny due to the pc native resolution hookup and it seems to have all the features I want. Can't see where the 58" is worth another $2K for 8", whattya think. It looks like the perfect tv for me. Thanks for the pictures - nice setup.:)
    Denon 3806 Receiver
    Denon 3910 DVD
    Oppo BDP-83 Blu-Ray
    SVS PB-12 Plus Sub
    Lsi25 Fronts-Cherry
    LsiC Center
    LsiFX Surrounds
    SMS-1 Velo Sub EQ
    PBJ Interconnects
    Blue Jeans Cables
  • Holydoc
    Marc,
    As far as whether the 58" is worth the price, that has to be your decision. I know I have never heard anyone ever say, "I wish I would of bought the smaller TV."
    :D
