500rms monoblock for a 200rms rated sub? Can I do this?
Jack from Indo
Ye who are far more experienced than I, please help! Thanks.
500RMS monoblock for a 200rms rated sub?
As long as I set the gain safely, is this OK? Or, am I too overpowered anyway?
it would be a JL 500.1 amp with a rockford sub PS210
Reason why I would want to do this is fliexibility to add another sub, or a higher power rated sub, etc etc later.
Please advise this rank neophyte, thanks.
Post edited by Jack from Indo on
careful with the gains and you'll be more than fine.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Toxis wrote:careful with the gains and you'll be more than fine.
Unless of course you go after that poor 200 watt sub with a few hours of Bass Mechanik or some sustained test tones
. Boston Acoustics' "Woofer Cooker" wouldn't be an ideal track either.
Normal music with common sense gain settings and volume control should be A OK- normal listening shouldn't put too much heat into the voice coil that your sub wouldn't have a chance of dissipating. -
Yup.
Think of it like this, a typical car is capable of 120 mph. Does that mean its doing 120 mph all the time? No. Same with an amp. You can hook a 1000 watt amp up to a 50 watt speaker if you wanted to. As long as youre not giving the speaker so much power that it either overheats or overexerts the suspension it will work.polkaudio sound quality competitor since 2005
Greg Peters wrote:Normal music with common sense gain settings and volume control should be A OK- normal listening shouldn't put too much heat into the voice coil that your sub wouldn't have a chance of dissipating.
Totally agree...Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin
