pre outs?
brandnew1482
If I have the sony CDX-GT300 deck can do i ahve enough preouts to connect a 4 channel amp and a 2 channel amp? if i have 2 pairs of pre outs?
Post edited by brandnew1482 on
You don't have enough outputs to control them separately with your head unit, but some amps have what is called a "pass through" section that allows you to send the same preamp signal through the amp to another amp. Kind of a "daisy chain" type of useage.
This type of connection would be useful if you wanted to use the 4 channels for your main speakers and then send a signal on to a subwoofer amp that has crossover controls that cuts the signal for use only in the bass range.
Your other option is a separate active crossover that will divided the signal into the ranges needed for separate amplifiers. A single pair of outputs could run 2 or 3 other amps with a crossover like this.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
so if i get this amp for my speakers
http://www.crutchfield.com/S-XhlihtdwZpT/cgi-bin/ProdView.asp?g=120&I=489AP1040
and this amp for my subs
http://www.crutchfield.com/S-XhlihtdwZpT/cgi-bin/ProdView.asp?g=120&I=489AP1200
will i be able to run it off my head unit -
i dont get it..,..how many pairs of preouts do u need per amp...
if the specs say it has 1 pair pre outs how many amps can i run...2...3..?
mine says i have 2 pairs -
Sony CDX-GT400
this one says it has
2V Mono Subwoofer Preamp Outputs: In addition to the 2V front and rear preamp outputs, this unit includes one set of 2V mono subwoofer preamp outputs. Although there are two female RCA subwoofer outputs, the same signal is carried by both connections. A low-pass filter (see below) can be used to filter high frequencies from the signals output by the subwoofer outs.
so with that one i'd be good on the 2 amps right? -
According to that, youll have enough.
You need 1 pair per output for the amp. One is left and the other is right. So for a 4 channel and a 2 channel amp, youd need 6 total outputs.polkaudio sound quality competitor since 2005
so with http://www.crutchfield.com/S-esaFFfT6nVG/cgi-bin/ProdView.asp?g=300&I=158GT400
i can get a 4 channel and a 2 channel amp -
brandnew1482 wrote:so with http://www.crutchfield.com/S-esaFFfT6nVG/cgi-bin/ProdView.asp?g=300&I=158GT400
Yep, 3 sets = 6 channels.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
