Tube Amp Rant ;-)
samiam
samiam Posts: 70
edited November 2006 in Electronics
Here is my rant...why are solid state and tube amps so expensive? I mean, a good tube amp costs as much as a quarter at a state College!
Can somebody please explain, hypothesis, over-intellectualize, why these things are so un-freakin-believably expensive?
Phew, I feel better.
http://k43.pbase.com/g3/44/486444/2/56451195.sayahhh.jpg
Fronts RTI 8 Cherry (Bi-wired/ampd)
Center CSI 5 Cherry
Surrounds RTI 6's Cherry
(Currently fiddling with Mirage Nanosats for l/r surrounds)
MONSTER HTS 5000 MKII Power Conditioner
Marantz SR7500 Reciever
Home Brew PC Music Server/Gamer
Nintendo WEEEEEE!
Panasonic AX100 Projector
DIY Screen (for now)
Post edited by samiam on
  • scottvamp
    scottvamp Posts: 3,277
    Just real fast here,
    I bought a couple MPA3250's and they weight almost 100 pounds each. The sheer quality of the components inside and not to mention the insane "steel" stortage at the monent.
    Before seeing hi end gear in person, i also would ask the question.
    Seeing a 300 pound Krell mono block is pretty wild. Sitting next to your $199 Sony reciever it somewhat clears things up.
    Check out the "guts" thread, heavy hi quality parts, craftmanship, layout and design.
    Not into tubes but the hi end ones look the price. 24k bases and what not.....
  • Johncan
    Johncan Posts: 38
    buy used vintage tube amps!
    I did... saved a bunch.
    My main rig
    Eico HF-87 amp and Eico HF-85 preamp; Klipsch Cornwall I; Systemdek IIX TT w/ a Dynavector 10x4 MKII cart; Denon DVD-2910 universal CD/SACD/DVD-A/HDCD player - Polk Monitor 5s, 7s, & 10s used in secondary systems.
  • ND13
    ND13 Posts: 7,601
    What are you considering as expensive?? There are several high quality tube amps, that can drive virtually any speaker to concert levels effortlessly, that come in under $1500 and go on to $2k and you can add quite a few more.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • samiam
    samiam Posts: 70
    That's a nice rig, mpa3250, I think my bro-inlaw has something like that. Huh, 2 months ago I thought this when I saw it..."big box". Now I'm all about respect having listened to these beasts. I can't believe the richness that an amp makes.
    My rti8's only can handle 200 watts, so that is why I am thinking about going tubin. That being said, from what I have read, tube amps kick out as much richness as solid states but at half the wattage, amperage. That means I should be fine with a 50 watt amp for stereo listening.
    The reason for the rant is from looking into head amps actually. Check this out:
    http://cgi.ebay.com/Little-Dot-2-II-Headphone-Tube-Amp-Amplifier_W0QQitemZ190047408373QQihZ009QQcategoryZ3280QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    It has really good reviews for high-impedance cans on headfi.
    It got me to thinking....why can't they be made cheaper?
    Center CSI 5 Cherry
    Nintendo WEEEEEE!
  • samiam
    samiam Posts: 70
    Expensive is a relative term no? :) My price range is limited because I'm about to get the panny ax100/screen and a new couch. So in terms of what I would like to pay I'm talking 500 bucks tops. Yea. I know. Keep dreamin.... :)
    Center CSI 5 Cherry
    Nintendo WEEEEEE!
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    The Little Dot is entry level..............check out some of these.http://www4.head-fi.org/forums/showthread.php?t=7226
  • ND13
    ND13 Posts: 7,601
    You can pick up a nice pre-owned tube amp within your price range. All you need is an amp with 40-50 wpc(maybe even as little as 30) and you're set.
  • TroyD
    TroyD Posts: 13,093
    You can often find, for example, a myriad of vintage CJ tube amps for under a grand.
    Quit jerkin' the gherkin to Stereophile ads and use you noggin'. The gear is out there.
    BDT
  • ohskigod
    ohskigod Posts: 6,502
    also, dont rule out a good solid state amp just because your speaks are rated at 200 wpc. you can get an amp more powerful than that and safely drive them as long as your not a complete lunatic on the volume knob. remember, volume knob lunacy will eff up your speakers with a lower powered amp that clips, than an overpowerred one
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • madmax
    madmax Posts: 12,434
    You can pick up a nice Jolida 302 or 502 under a grand if you look real hard. I forget what I sold my 302 for but I think it went maybe $700? Not too far from $500 :)
    madmax
    Vinyl, the final frontier...
  • ND13
    ND13 Posts: 7,601
    madmax
    Yep, $700, and it drives my SRS 2s to any level I'd ever need them to ever go to.
  • madmax
    That little dot head amp should be cool enough for the price. I didn't realize you could find a tubed head amp that cheap.
    madmax
  • madmax
    Oh, and what I got when I switched from SS to tube amps was a certain loss of a garbling sound that most SS units make. Never heard it until switching back after listening to tubes. It was everywhere. I heard it in the car even. I ended up selling most all of my SS stuff soon afterwards. :)
    madmax
  • samiam
    samiam Posts: 70
    Really? 40-50 huh...hmmm....even with the combo setup I have? I am wondering, what sort of changes would an entry level tube amp like that bring. Feel free to get flowery. Use terms commonly found in wine tasting if you wish. :)
    Center CSI 5 Cherry
    Nintendo WEEEEEE!
  • organ
    organ Posts: 4,969
    Matching the speakers and amps is the key. The RTi sounds killer on tubes.
    I can tear down the house with 5 w/ch.
    Here's a link that give you the basics... http://www.theabsolutesound.com/newsletter/147/tubes_vs_trans.html
  • sucks2beme
    sucks2beme Posts: 5,606
    madmax
    Stick with the Little Dot II+
    The original LD and LDII use some odd tubes.
    I think they were going for about $139 + shipping on Ebay.
  • 55LS70
    55LS70 Posts: 184
    Right now I'm listening to my new PrimaLuna Prologue Four. It's 35 wpc EL34 amp. Just got it today, brand new and $1183 delivered to my door. It's build and sound quality blows the Dynaco ST70 series II it replaced away. Wait awhile and there no doubt be used ones coming up on the market.
    Decware CSP3 Preamp, RCA 6DJ8, 2 X Rocket 6N1P-EV's, Cary SLA70B Signature V2 Amplifier: 2 X Mullard GZ32's, 2 X RCA/GE 5691's, 4 X Tung-Sol 6550's
    Cambridge Audio 640C V2 CD Player & Dacmagic DAC
    Rega Planar 3: Deep Groove Subplatter, P3 Motor
    upgrade, Dynavector 10x5, JA Michell counterwieght, Cardas tonearm wiring and Mapleshade stand
    Parks Audio Budgie Hybrid Phonostage with BEL 6922 tubes, Polk Audio LS70's
    H.H. Scott 330D AM/FM Tuner with H.H. Scott 335 Multiplex adaptor.
