Are bipole/dipoles appropriate?
univera
I just got my HT up and running and intended on using FX500's for my rear channel in a 5.1 setup. My installer wasn't very keen on my using these speakers for the rears since my couch/listening position is directly against the back wall that the FX's would be mounted. The Polk manual doesn't give this setup the ideal reccomendation.
These are rather large speakers and I don't intend on mounting them at ear level or close to it as it just doesn't make sense in my room from a "looks" perspective. (I would consider doing so IF there was consensus that this option would be good in spite of the couch being on the back wall.) Therefore, one will go in the top corner and the other in line with my front, right speaker (no perpendicular wall to make a corner on that side to mount or reflect off.) I currently have them sitting on a table next to the couch and below ear level, so its hard to judge how they will sound once mounted.
Would I be better off just using direct radiating speakers for high placement? I also have a pair of NHT Super Zeros I previously used near ear level that sounded great for their size, but the I thought something larger was needed for the SDA's. I'd like to mount whatever speaker up high, out of sight since my room is dominated already by large speakers and thought that if I played with the delay, I could get it to sound pretty good.
UNIVERA
Historic Charleston SC
2 Channel:
SDA-SRS's RDO tweets
Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
Anthem Pre 2L w/E.harmonix platinum matched 6H23's
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
DVD: Toshiba 3109 dual tray
Subs: Velodyne and M&K
T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
Conditioner: Panamax M5100EX
Master Bedroom Sony 40KDL-XBR3
"I love it when a plan comes together." Hannibal Smith, The A-Team
2 Channel:
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
Post edited by univera on
Having you couch and listening position directly against a back wall for HT is about as bad as it gets. And it sounds like you sides are not much better. With that said just side mount the FX500's - that is what they are designed for. The fun part of HT is experimenting - ultamatly, it is going to be what sounds best to you.
I would use a bi-pole speaker over a direct rediating speaker for surround duty no matter where they were located in relation to the seating area.Proud SOPA Member since 2005!
Agree 100%. In a 5.1 setup ofcourse.nebborjk wrote:I would use a bi-pole speaker over a direct rediating speaker for surround duty no matter where they were located in relation to the seating area. -
My thoughts exactly. I figured that dispersed sound would give a better result than a direct radiating speaker. It seems that a direct radiating speaker can have better pinpointing of sounds (like bullets) whereas multi-poles would present a larger, more dispersed sound with possibly a larger sense of space. I could mount one on a side wall, but the other wall is wider than my front, right main and is an exterior wall without access to the attic.
I can't mount them up high with intentions of moving them and I can't just hold them up there to listen. If I go with any speakers, is mounting at ear level the best option? One set of holes is all that will be happening. More opinions appreciated.UNIVERA
2 Channel:
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
"I love it when a plan comes together." Hannibal Smith, The A-Team -
Hang em high... wasn't that a movie?
Use the FX500's on the wall.. they will sound very good. trust me. in bi pole mode. i'll always use bi pole speakers over direct radiating ones.
Why do you think Polk designed them? For surrounds of course.
Is ear level your only option?PolkFest 2012, who's going>?
danger boy wrote:Hang em high... wasn't that a movie?
No, ear level isn't my only option. I just thought that was ideal, or a bit above ear level. I really want these up high out of sight. Of course they are for surround, but it seems they benefit from sidewall placement.UNIVERA
2 Channel:
CDP- NAD C 542
HT setup:
AVR: NAD T 773
Rears: Polk LC80i
Take a look at my surrounds. They are pretty high and they sound good.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Isn't the ideal 2 to 3 feet above ear level? However, I am sure it would depend on how far they are away from you (closer-probably a little lower and farther a little higher).
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
imo the fx's are superior to monopoles regardless of position; speaker or chair. Merely set them to either bipole or dipole, as to your convience and preference.
