Are FXi5s 'Surround Back' or 'Surround' Speakers
I just purchased my first HT system and am setting it up. I have a Denon 4306 receiver, and I have the option to connect the FXi5 speakers as 'Surround Back speakers' and/or 'Surround speakers'. (The Denon manual shows many different setups, with both 'Surrounds' and 'Surround Backs' being in the same position.. but of course there's different jacks on the Denon for the two)
Should the FXi5s be set to BI-Pole and connected to the receiver as 'Surround Back'?
Thanks,
Dustin
BTW - it's a 5.1 setup with 2 RTi10s, CSi5 center, 2 FXi5s, and 2 MartinLogan Abyss subs. (so I guess it's a 5.2 )
Thanks,
Dustin
Post edited by DustinS on
For a 5.1 configuration you'll want to setup the FXi5's as Surround speakers. Surround Back speakers are for a 6.1 or 7.1 configuration.
As for Bi-Pole/Di-Pole, this depends on where you plan to locate the speakers. Refer to the owner's manual to find the installation example that most closely resembles yours. Or try them both ways and see which way you prefer.Proud SOPA Member since 2005! -
My FX's are set to Di-Pole due to the geometry of my house not working for getting the speakers behind me with my couch config (damn diagonal fireplace!). Di-pole sends the sound out on a 45° angle from center line of speaker where Bi-pole sends the sound straight out the front of the speaker (perpendicular to the wall).Denon 3806 Receiver
Denon 3910 DVD
Oppo BDP-83 Blu-Ray
Outlaw 7500 300w x 5 @4 Ohms Amp
58" Panasonic 800U 1080P Plasma TV
SVS PB-12 Plus Sub
Lsi25 Fronts-Cherry
LsiC Center
LsiFX Surrounds
SMS-1 Velo Sub EQ
PBJ Interconnects
Blue Jeans Cables
Everything was going just fine till my buddy poked the cop in the chest and said "did Andy give you your bullet today Barney?"
