pre-pro upgrade!
dholmes
dholmes Posts: 1,136
edited October 2006 in Electronics
Ive recently got the upgrade bug, I been looking at the new Adcom 870 hd pre-pro with 1080p upconvert with hdmi.Adcom has a trade up program with most pre-pros as a trade in, my Sherwood p-965 & 1800.00. The Adcom sells for 2500.00. Just wondering if the Adcom is better than the Sherwood. Also the 1080p output wouldnt help me with my projector Panasoic 900 because it cant handel 1080p, just 720p. One more thing Im confused with the new digital sound from hd & blu-ray, will any pre-pro accept the new sound with hdmi? I keep hearing different stories that some do, but Denon says theres none out there yhat can decode it! Sorry lots of questions, thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • sickicw
    sickicw Posts: 456
    edited October 2006
    there are none out there that can decode it yet, but most of the brand new ones, can take the 6 channel pcm signal via hdmi 1.1 that was decoded by the blu-ray or hd-dvd player. It is probably better this way (because the player can mix in other stuff into the decoded pcm) as long as the player(hd-dvd or blu-ray) can decode all the formats you are interested in. The only problem i see right now is that some of the current players dont decode dts-hd Master.
    Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
    Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
    Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
    Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture.
  • dholmes
    edited October 2006
    thanks,
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited October 2006
    I don't know ..the Sherwood is a really sweet processor for the dough. I spent a lot more than $2500.00 to successfully upgrade it. Also, if you don't like it you are stuck. I would just buy the Adcom outright and try it out from somewhere with a good return policy. If you like it - sell the P-965..if not - return it.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
