LSI question
I was wounder what you guys would advise. Im going to start replacing my rti system to all LSI over the next month. Im only going to be using a 3 ch setup with a sub to start. Im looking at the Adcom amps on ebay is anyone running muilt amps for a 5 ch system or is everyone just using one amp. What i was thinking for the prices that they seem to be goping for i was going to go with a 5400 or 555 amp for the LSI15 and a 2535 or 5300 biamped. I will beadding another amp for the rears when i add them if this setup sounds ok .
If you have the space, I don't think it would be a bad idea. I have one amp for my fronts and another for my center, works fine.
There are some three channel amps out there, if you're looking to save space. Then you can add a second amp for the rears later on.
Good luck!Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
