HD Dolby and Preamp support
marcpam
I have a 950 outlaw preamp. Now, with the new format of HD sound coming out (Dolby HD etc.) will i still be able to support the new upgrade sound format?
Post edited by marcpam on
According to Dolby's site, Dolby TrueHD is "compatible" with current Pre/Pro's, but that term makes me assume that while audio will play it won't be outputting the fullest potential.
I guess it comes down to wether or not full implementation requires a new physical processor or can be done by a firmware update. If your Outlaw has a USB or RS232 connector for updating firmware, I'd say there's at least a chance.Dodd Audio ELP [ Tubes ] // Harman Kardon AVR330 // Parasound HCA-1203A // Denon DVD-2900
Polk Audio LSi9, LSiC, LSi 7 // HSU STF-2 // Signal Cable Interconnects (SG BW/A2/MP) -
An other option may be for the HD-DVD or Blu-ray player to decode these new formats and send them through multi-channel analog outs to a pre-pro or AVR's multi-channel analog inputs.
This would be a stopgap until pre-pros and AVRs come equipped with the ability to decode the new formats.5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5. -
You're not going to be able to listen to the true Dolby TrueHD unless you use the analog outputs on the DVD player itself. There is a DD track on the next gen DVDs so you can listen to that on your current receivers.
For those looking at getting a receiver with the decode ability for TrueHD and DTS-HD, they should be announced pretty soon... CES at latest.Brian Knauss
ex-Electrical Engineer for Polk -
You can always use HDMI output to get TrueHD also.
Mike -
I thought that none of the current avr & pre-pro could decode the new new sound from hd-blu-rayMy HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
MikeC78 wrote:^^^
Mike
No current AVRs/preamps do that. Once HDMI 1.3 + the TrueHD/DTS-HD decoders are added to AVRs (that's sort of redundant), you'll be good to go. Like I said, you should hear lots of news by CES.Brian Knauss
As of right now you cant enjoy true Hd from the blu-ray camp, however you can currently enjoy it with HD-DVD using your current setupShoot the jumper.....................BALLIN.............!!!!!
Sorry, let me make myself more clear.
No current AVR can decode TrueHD. The player (I ment HD DVD player) can decode TrueHD 5.1 and send it as PCM to you AVR via HDMI or analog out.
Mike -
bknauss wrote:No current AVRs/preamps do that. Once HDMI 1.3 + the TrueHD/DTS-HD decoders are added to AVRs (that's sort of redundant), you'll be good to go. Like I said, you should hear lots of news by CES.
You don't need HDMI 1.3 to take advantage of TrueHD/DTS-HD.
Mike
