Speaker/TV help/Proper HT
Home Theatre
How far should your speakers be from the wall?
How far should your front speakers be from the center/TV?
How far should you be sitting from your tv?
Everything I own burned in the fire!!!!!!!!!!
Post edited by Home Theatre on
How far should your speakers be from the wall? 40 yards
How far should your front speakers be from the center/TV? 38.9 yards
How far should you be sitting from your tv? far enough to reach the chips"she had the body of Venus, with arms." -
Polk_audio_lsi
ninerbj wrote:How far should your speakers be from the wall? 40 yards
Are you begin serious?Everything I own burned in the fire!!!!!!!!!! -
Your speakers (mains) should form a equalateral triangle with your primary listening position. As far as how far out from the rear wall, tough call. Most people recommend keeping the fron 3 speakers on the same plane. Seating distance from the screen will vary, it really depends on the screen size and your personal preference.
Don't be afraid to try various placement options, thats half the fun! Remember to recalibrate after each speaker movement.
This should help get ya started. -
Thank you that helps a lot.Everything I own burned in the fire!!!!!!!!!!
