Bi amping LSI25
jln9
jln9 Posts: 16
edited October 2006 in Speakers
Im looking at going with a 7 CH amp rated 200 into 4 ohms. I have saw on a few recivers that in a 5.1 setup you can take the leftover ch and use thoses as a biamp ch. IS that true ann who much is to much power for the LSI.
Post edited by jln9 on
  • MikeC78
    MikeC78 Posts: 2,315
    edited October 2006
    Just a heads up...
    This has been beaten to death a million times on here. You can do a search on "bi-amp", "LSi25", and "Amplifiers" and you will find numerous threads full of answers.
    Mike
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited October 2006
    If I recall......................you can't biamp the LSi25. It isn't wired traditionally.
  • Ruin
    Ruin Posts: 59
    edited October 2006
    Correct. The only biamping you really do with the 25s is to run the sub portion seperately from the rest. The top three drivers are all wired into the top terminal so removing the jumper does not seperate those out.
    Ruin
    Denon AVR4806CI
    Denon DVD3930CI
    Panamax 5500-EX
    Polk LSi25 mains/subs
    Polk LSiC center
    Polk LSi9 Surrounds on Custom Skylan stands
    Mitsubishi WD-65831
    Audio Art IC-1 Interconnects
    Audio Art SC-5 Speaker Wire
