Volume Level on New Pre-amp.
McLoki
I just purchased a new pre/pro to run instead of the AVR I was using. With my old avr if the levels to all the speakers was from +1 to -3 it calibrated to reference level.
With my new pre/pro I have to calibrate all the channels from +6 to +2 to calibrate to the same level.
My question is, should I try and calibrate to keep the speaker levels around zero (about 5 under reference level) and just run the amp a little harder, or should I go ahead and set the channel levels higher and calibrate to reference?
I did not see anywhere to change the sensitivity of the Pre output nor the amp input.
Thanks for any suggestions you can give.
Michael
Michael
Post edited by McLoki on
I would run it overall hotter to keep the higher level of adjustment. I like to have quite a bit of adjustment available for my center as I find some tracks that seem to need center boosting.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
If you don't mind me asking how much does a preamp like that run you?Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar -
millerman 3732 wrote:If you don't mind me asking how much does a preamp like that run you?
Retail is $1500 new. You can usually get it new for 1200-1500 depending on the dealer. Used is normally $750-$900.
I paid the bottom of the used range. (it is in like new condition, and the firmware has been upgraded to support PLIIx. (although since I only run 5.1, it really doesn't matter))
I take it that you're telling us about the NAD??"SOME PEOPLE CALL ME MAURICE,
CAUSE I SPEAK OF THE POMPITIOUS OF LOVE" -
Yes, I thought that was what he was asking about. (and it is first in my mind since I just got it on Friday)ND13 wrote:I take it that you're telling us about the NAD??
What other preamp where we talking about?Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
If you listen to music, here's something to try. Put it into stereo. Then play with the levels on the main L/R. If you find that a particle level setting sounds best, use that, and adjust the spl of your other speakers to match.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
McLoki wrote:Retail is $1500 new. You can usually get it new for 1200-1500 depending on the dealer. Used is normally $750-$900.
There are a couple on e-bay (one left) that seems to be going in the $500-$600 range. (to late to help me, but if you are in the market, they seem to be a good deal.)
