Niles Multi-Zone, and iPod Install
SKsolutions
Has any installer here intergrated an iPod into a multi-zone distributed source system. I'm using the Niles 8630AV www.nilesaudio.com/product_selection.php?catcdID=2
with 6 Niles T2 touch sreen access panels. I'm looking for a dock that will allow remote operation of the iPod. I know there are docks that will talk with Onkyo's RI system, but this install is using separate receiver/preamp and B&K amps. I'd like to not use IR repeaters, but will if I can't find other solution. Big thanks,
Sean
Sean
-Ignorance is strength -
Post edited by SKsolutions on
I thought the Niles Smartdock could be controlled through the keypads, but after doing a litlle more research, I don't think it can.
I'll do a little more research to see what brands might be able to work with it. My initial response is that you will have to use an IR repeater system.Tschüss
Zach -
Anything would be better than what I've been able to find, and would be greatly appreciated. Thanks.
Sk-Ignorance is strength -
