benefits of biamping
kismetcapitan
I'm thinking of getting rid of my rear speakers and then dedicating my C400.4 to just my front separates - two channels for tweeters, two channels for woofers. I'll be driving half the speakers with my amp, but what are the upsides to biamping?
1991 Nissan Skyline GT-R, Nismo Omori/Momo interior and Polk/Momo stereo (C300.2/C400.4/MMC6500/MMC650/MM2104DVCx2, and Sony BT5000 bluetooth head unit)
Post edited by kismetcapitan on
I belive the main benefit is control, but you get added power as well. Instead of splitting your X watts per speaker, you're effectively getting all the channel's power to the woofer, and all the other channel's power to the tweeter. You can balance your gains on the amp to get the tweeters at the right levels.
I've been playing with setting my fader all the way forward and just playing through the fronts and through my subs. Sounds good, but the only trouble is my best speakers are in the rear! Now i gotta get the MMC6500 for the front, to make the fronts up to par.
MacLeod really knows this stuff, so hopefully he'll chime in with his far more experienced opinion.1999 Honda Civic LX - 105 gerbils at the flywheel!
Sony CDX-GT100 Head Unit
Rockford something or other 6.5" in the front. I'm taking donations for MMC6500's!
Polk Momo MMC690 6x9's in rear
Polk Momo c300.2 amp via 4ga. and a 1.5 Farad stiffy :eek:
Polk db804 8" Subs x 2, in sealed box. -
The benefit to bi-amping is control like was mentioned above.
Bi-amping will allow you a lot more flexibility in tuning the output of the tweeters as opposed to the -3 and -6 db attenuator on the crossovers.
Also if you use time alignment you can add delay seperately to the tweeters which more than likely you wont but its nice that you could.
And bi-amping will let you use those badass crossovers on the 400.4 so you can try different settings and see if any of them sound better.
Bi-amping is the only way to go as far as Im concerned, especially if youre a tuning freak.polkaudio sound quality competitor since 2005
so the gains of biamping the fronts are clear - are there any real losses by eliminating the rear speakers? Logic says that they're not required in any real way, but years and years of having rear speakers...it's a hard paradigm to break!1991 Nissan Skyline GT-R, Nismo Omori/Momo interior and Polk/Momo stereo (C300.2/C400.4/MMC6500/MMC650/MM2104DVCx2, and Sony BT5000 bluetooth head unit)
The only thing that will suffer by losing the rear speakers is the soundstage for your back seat passengers.
So if youre wanting them to have the best sound possible, then you should keep them. If not, the best sound for you will be to lose em.polkaudio sound quality competitor since 2005
amen.kenwood excelon kdc-x991 h.u.
Rockford Fosgate 360.3 DSP
Rockford Fosgate POWER1000 running entire system
Image Dynamics IDQ12 Sub
Morel Elate 6 front stage -
Some people prefer to run their system with rear fill. Depends on what your ears like. In a system with rear fill that is properly setup, you should not really be able to tell that the rears speakers are on.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
just read the first section, it gets really technical from that point onward. basically, it eliminates dropouts in the frequency spectrum of the crossover. so..you get more clarity. there are actually more pluses than negative aspects of bi-amping. everyone should do it if at all possible.
http://sound.westhost.com/bi-amp.htm:)currently in car:
'00 Honda Accord LX V6
AEM V2 cold air induction
c400.4 amp powering a pair of momo 6500's
and a pair of momo 6x9's
alpine monoblock amp powering a jl w3 12''
custom fab work for tweeters
jl rca's, dist block and power/grounds
alpine cda 9857 head
three ground loop isolators
ipod integration, all songs at 320kbs -
iworkfortweeter wrote:just read the first section, it gets really technical from that point onward. basically, it eliminates dropouts in the frequency spectrum of the crossover. so..you get more clarity. there are actually more pluses than negative aspects of bi-amping. everyone should do it if at all possible.
Link doesnt work brother.
The only real negative I can think of is having to buy and run an extra set of RCA's and speaker wires......which can be a big deal to a lazy person.....like me.polkaudio sound quality competitor since 2005
there ya go...that's the right one.At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:(
