Carver amps - stable to 2 ohms
BlueMDPicker
I'm running the Carver Research Lightstar Reference amp (600w @4 ohms, 1200w @2 ohms) on the ESL panels of my Innersound Isis speakers, and a Nikko Alpha 230 (130w @4 ohms) on the transmission line woofers (horizontally bi-amped with Marchand active crossover.) The combination sounds very good, but the Nikko is running a bit hotter than it has in other applications.
The nominal impedance of the Isis, passive crossover, is 4 ohms. In active crossover operation, I suspect the panels are close to 2 ohms nominal and the woofers 6 ohm nominal. Theoretically, I should be running the lower output amp on the panels and the higher output amp on the LF. But, the Nikko can't handle anything below 4 ohms. So, eventually, I'll replace the Nikko with something that can handle <4 ohms and switch the amps around.
I know there are several of you who have had, or are using Carver amplification. Which Carvers can really handle a consistent 2 ohm load reliably?
Thanks!
Thanks!
Post edited by BlueMDPicker on
Silver 9t mono--1000 @ 2ohm, they dont break any sweat at 4 ohms with the Amazings in the Shed which is 1232 cu. ft.
Having fun I see !!!!!!!!!!!!
RT1 -
reeltrouble1 wrote:Silver 9t mono--1000 @ 2ohm, they dont break any sweat at 4 ohms with the Amazings in the Shed which is 1232 cu. ft.
RT1George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
IIRC, the lightstar is basically the same design as the Sunfire, which are 2ohm stable.
The Silver 9t's/TFM-45/m4.0t....those all should do the trick nicely.
Troy,
Yeah the Lightstar was the run-up to the Sunfire from what I've read. The Lightstar isn't at issue with the ESLs, it loves them and runs no harder than it did into the SRS. It has such great tone that I shudder at the thought of replacing it. -
So look for a used Sunfire, the 300wpc stereo models can be had 'reasonable'....
Hooked-up, issue resolved. Gotta' love CP. There's more amplification changing hands here than side money at an alley crap shoot.
The Sunfires will play at 1-2 ohms with no problem. And for bass duty it would be a reasonable match with your Lightstar.
The Silver 9t would be perfect though. Added fidelity, built like a tank, reliability. I used one for awhile with 4 bass transducers wired series/parallel. Measurment wise they read at 4 ohms but I know they had huge impedence differences dynamically. I could turn the volume up and watch my home lighting dim. Those meters can bury themselves in the red with the amp showing no sign of stress.
I run my Martin Logan CLS with a pair of Carver Silver 7t amps without any issue. Previously I have run them with a m1.5t (clip at will), TFM-35 (had to work a little to hard for my taste), A-500x (a lot better and stable to 2 ohms), A-760x (only bettered by the 7t and stable to 1 ohm).
Thanks for the info, madmax and Wardsweb. I'm trying the A500X you had first, WW. But, I may purchase some Silver 9Ts as well for future neurotic adventures in audio.
BlueMDPicker wrote:There's more amplification changing hands here than side money at an alley crap shoot.
You said it brother! I'm warn out already:D -
Bob McG ran bridged M1.0-t's to 1c's and 2.3's for years. I know not quite a true 2-ohm load, but about as close as you'll get without doing something funky.
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d -
Mike, get some man amps, pronto.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
The panels range from 112 to 2 Ohms, 500Hz to 20KHz. The Seas woofers in the Eros are 4 Ohms. Not sure if the Isis are the same.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
I had a nice long conversation with Roger Sanders last week.
He recommends that the woofers have a minimum of 200w into 4 ohms tho I'm sure your Niko is fine. It'll just run a bit warmer.
Of course, he was attempting to persuade me into real man amps like his ESL amp for the panel and the 600w into 4ohm bass amp -
RT1
I know a guy locally that used to be into high end audio, but over the years, a marriage and multiple moves, he is no longer into and wants to sell me his Carver Silver 9T's. He said he bought them in the mid-90's and used them for about 6 months. What do you guys think of these amps? I may be able to get a nice deal. I have heard mixed reviews so far, powerful but not very musical.
What do you guys think they are worth today?
Thanks,
Venom -
venomclan wrote:I have heard mixed reviews so far, powerful but not very musical.
Thanks,
Venom
$600 each is reasonable. Possibly a little more if they were really only used for 6 months. Musical? Depends on your reference. They are more musical than any of the other Carver or Sunfire stuff. If comparing to the upscale tube equipment, the high end MF gear or other very expensive class A amplifiers then you could claim them to be non-musical. What class do you choose.
SCompRacer wrote:The panels range from 112 to 2 Ohms, 500Hz to 20KHz. The Seas woofers in the Eros are 4 Ohms. Not sure if the Isis are the same.
Thanks for the info! -
Normanality wrote:I had a nice long conversation with Roger Sanders last week.
Is there a pissing match between Roger and the new owner(s) of Innersound? Innersound changed their web site recently (last three weeks) and eliminated any information or reference regarding "legacy" products. IMO, these sort of moves really do a disservice to the audio community and potential resale. I've had the same disappointing experience with Dodd Audio. -
madmax wrote:They are more musical than any of the other Carver or Sunfire stuff.
RuSsMaN wrote:Mike, get some man amps, pronto.
BlueMDPicker wrote:Wow, hard to imagine that from the hours I've had with the Lightstar Reference. The problem with running 9Ts in the vinyl rig with horizontal bi-amping through an active crossover would be the need for 4 of them, if they're true monoblocks.
No,no. The Lightstar was not mentioned for a reason. I did not intend to include it under the "Sunfire" group. I thought that was a seperate endeaver...
venom,
I find the 9t's to be musical in my rig, in Chuck's words "Everything depends on Everything". I would say between 12-15 hundred depending on use/condition.
RT1 -
BlueMDPicker wrote:Bingo! Yeah, I made the assumption the woofers were 6 ohm. The Nikko has never run even warm @5-8 ohms.
Actually, yes, big pissing match. There's some public posts regarding the situation that I won't repost. I'll be glad to pm you links. Bottom line, the original Innersound is no longer producing speakers, much less anything.
Roger Sanders, the original owner and design engineer of everything Innersound, has reimerged as www.sanderssoundsystems.com He is a delight to talk to and very willing to help out with all the original Innersound products.
Sounds like Carver doesn't it? -
Normanality wrote:I'll be glad to pm you links. Bottom line, the original Innersound is no longer producing speakers, much less anything.
I've looked at Roger's new website. I believe you gave me the link a week or so ago. Hopefully, he'll put some specs and manuals (in PDF) online sometime in the future. Steve Rounds had the same assesment of him when we discussed my purchase of the Isis. Cool! -
madmax wrote:$600 each is reasonable. Possibly a little more if they were really only used for 6 months. Musical? Depends on your reference. They are more musical than any of the other Carver or Sunfire stuff. If comparing to the upscale tube equipment, the high end MF gear or other very expensive class A amplifiers then you could claim them to be non-musical. What class do you choose.
madmax
Thanks Max and Reel,
There are a couple of reviews on audioreview.com that claim the 9t's are not musical. I too take this with a grain of salt. Musical is a subjective term. I use all SS amps with digital sources. I can usually relate "musical" to warmth. My Adcom is on the warm side, my Krell is more detailed. Outlaw=neutral.
I am going to see if I can demo these first before I make a decision. If I can get a good deal it may sway me. He told me to make him an offer for the pair. I will let you know if it pans out. Thank you for the input guys.
One last thing, do the Carvers have balanced inputs?
Venom -
They have the standard RCA type inputs. They were going for $1299 each new in the early 90's. Thinking back on it I think I was low with the $600 each. I've actually seen some pretty crappy looking ones go for that. It is a plus if they have the acrylic or glass stands they came with also.
Yes a bit low MM, I was recently advised to list mine at 1500.00 as they are as near mint as a used piece can be and have the stands, a box and the manual.
If I were describe the carver sound in my rig in the ShedI would say just a shade to the warm side of neutral as you stated a demo in yours is the best way to tell.
I just had some warm/neutral gear up at the fest and in that lively room things sounded different than what I am accustomed to hearing with my stuff in the shed.
RT1 -
reeltrouble1 wrote:Yes a bit low MM
RT1
I know, I know... I think they call it geezing. Actually, the $600 apiece ones I had in my mind were pretty darn rough looking, nothing but the amp and were quoted as "worked last time I used them".
BlueMDPicker wrote:The owner's manual doesn't list the model number of the woofers used..
They were custom made by Seas to Roger's specifications for the transmission line woofer system.
Roger suggested that the tube amps we are using might not be powerful enough for the woofers. That was based on him thinking we had huge listening rooms and listened at 95dB 20 feet away from the speakers like most serious audiophiles. I'll get my hands on a scope to see where we are at with the 22VRMS we have available while playing some demanding music.
His ESL amp white papers are an interesting read too. His panel amps are high voltage rather than high current.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
BlueMDPicker wrote:Innersound changed their web site recently (last three weeks) and eliminated any information or reference regarding "legacy" products.
Mike, the link is gone but the pages are still there. http://www.innersound.net/transline.html
Might be a good idea to print everything in the event he takes them down.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
