ideas for a preamp and amp for rti8 or rf-82
Chicomoralessxm
Any suggustions for a pre-amp?? I'm looking to setup mainly for music...... would a the pre/out on the a receiver like the rxv-659 be ok or should I go with the pre/amp. and sep amp??? my budget is a bit tight. How good are the pre-out on these receiver the denon and yamaha or HK???
Chicomorales:)
Post edited by Chicomoralessxm on
Chicomoralessxm wrote:Any suggustions for a pre-amp?? I'm looking to setup mainly for music...... would a the pre/out on the a receiver like the rxv-659 be ok or should I go with the pre/amp. and sep amp??? my budget is a bit tight. How good are the pre-out on these receiver the denon and yamaha or HK???
Using your receiver will probably be fine as a preamp. The amp section is usually more important. A seperate preamp/amp will give you the best performance. For 2 channel only, a nice integrated will work ok too. Check out the used market for the Parasound 850 pre, it can be found for under $200 is has had very good reviews. A giant killer of sorts. Good Luck.
Venom -
I would personally suggest being patient and looking to see if you run across any good deals on separates or, as venomclan said, a good integrated. I don't know what your budget is, but you should be able to get a decent pre and tube amplification (if you go with Klipsch), or a tube integrated (again, if you go with the Klipsch), for no more than $700, and possibly for as little as $4-500.
Just for instance, I bought my Parasound P/HP-850 and some ASL Wave 8 tube monoblocks off the FM here for a total of $590. You should be able to put together a similar system for a similar price.George Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Some one told me the RTI8's aren't good for music is that true??? are the klipsch's good for music what about paradigm?? The parasound 850 you are suggusting?? should i use that with lets say the denon 2307 or rxv659 through the preamp?? or buy a seperate pre amp???Chicomorales:)
