Possible blown sub voice coil?
joeaudio26
Hey, just need some info on a sub i was playing a bass cd when subsonic bass kicked in and my sub eled, like ive never heard it do and all the bass was off at the time it still plays but is it possible it may of caused some trama to the cone or coils its a dual 4 ohm sub.
any info is welcome.
Whatsoever thy handfindeth to do, do it with thy might; for there is nor work, nor device, nor knowledge, nor wisdom, in the grave, whither thou goest.
Post edited by joeaudio26 on
It wasnt subsonic bass because you cant hear subsonic bass.
What does eled mean?
If its still playing, it isnt blown.polkaudio sound quality competitor since 2005
MacLeod wrote:It wasnt subsonic bass because you cant hear subsonic bass.
eled was supposed to be led dont know why it messed up sorry mac thanks for the info.:DWhatsoever thy handfindeth to do, do it with thy might; for there is nor work, nor device, nor knowledge, nor wisdom, in the grave, whither thou goest. -
joeaudio26 wrote:eled was supposed to be led dont know why it messed up sorry mac thanks for the info.:D
the site wont let me post the word how strang sorry againWhatsoever thy handfindeth to do, do it with thy might; for there is nor work, nor device, nor knowledge, nor wisdom, in the grave, whither thou goest. -
Im so confused.
MacLeod wrote:Im so confused.
mac,what im saying is my sub made a loud popping sound when playing the bass cd. And the cd says on the cover contains subsonic bass . its a cd from bass mekanik i was just wanting to know what caused it to do that cause it wasnt turned up that loudWhatsoever thy handfindeth to do, do it with thy might; for there is nor work, nor device, nor knowledge, nor wisdom, in the grave, whither thou goest.
