Stands and mounting help for LsiFX and LSiC
I want floor stands for the LSiFX surrounds and a wall mount shelf for the LSiC - any advice? Not many good options online. Not even sure what's compatible. What do you guys use or recommend?
Thanks!
Brian
Thanks!
Brian
Post edited by bdz1 on
Plateau 30" ST-SERIES stands filled with lead shot. The LSiC sits on the TV. I see the centre channel on floor stands in a lot of ads. I am not sure if it is too low, but sure looks nice. Good luck.Michael
NORTH of 60° -
If you are thinking wall shelf for the LSiC, have you considered just mounting it directly? It is designed with keyholes and one set of legs(spacers really) to hold it out from the wall.
RuinDenon AVR4806CI
Denon DVD3930CI
Panamax 5500-EX
Polk LSi25 mains/subs
Polk LSiC center
Polk LSi9 Surrounds on Custom Skylan stands
Mitsubishi WD-65831
Audio Art IC-1 Interconnects
Audio Art SC-5 Speaker Wire
