CSi5
Sherardp
Sherardp Posts: 8,038
edited October 2006 in Speakers
Hey guys,
Got a little extra change and was thinking of buying another Outlaw M2200 to biamp the my center(CSi5), would I notice any improvement over letting the Sony 7100 handle the job? Another thing is that my AVR is rated at 170 wpc(its actually 158 all channels driven), would I possibly blow anything since the center is rated at 200 watts. If I want get a significant gain out of this then I will just leave my setup as is. Thanks guys for your input.
Post edited by Sherardp on
  • aaharvel
    aaharvel Posts: 4,489
    edited October 2006
    If that Sony is really putting out 158x7, (no offense, but I'd have to see it to believe it), I would just stick with the Sony. Seriously. That's alot of power and should drive the csi5 just fine, if not adequately. Doubling the power only creates a +3db. increase in volume, so by those numbers alone you're only going to get about a .4 db increase in overall volume. The main difference is the sound quality you get from the extra power. If it sounds good to you as is, I wouldn't worry about it.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • joeparaski
    joeparaski Posts: 1,865
    edited October 2006
    I run a 100 wpc amp to my csi5. I removed the jumpers and run the left channel on one and the right channel on the other.....bi-amp?
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • Sherardp
    edited October 2006
    Heres where I got my info on my Sony.
    Ultimate AV Ultimate STR DA7100ES Benchtest Results-
    Driving all seven channels into 8 ohms, the Sony delivered 159Wpc at 20Hz and 123Wpc at 1kHz (to the nearest watt) before clipping (1% THD+noise). This measurement was repeated several times with the same unusual result.
    Into 4 ohms, all seven channels operating, it delivered a more consistent 125Wpc at 20Hz and 127Wpc at 1kHz.
    With only two channels operating, at 1kHz, the Sony clipped at 216Wpc into 8 ohms and 294Wpc into 4 ohms.
  • aaharvel
    edited October 2006
    ah.. no wonder. the benchtest isn't a real 20hz-20khz. test. Driven to the full audio spectrum with all channels running simulataneously, the wattage will be lower.
    That being said, if you have all of your speakers paired with the Sony, and you like the sound, then I'd stick with it. I'm a big fan of ES equipment, but Sony, like most others, fudge their wattage measurements.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
