Tv cable for radio antenna?
MSALLA
I was told by a co-worker to put a splitter on my cable for the tv and run it to the recv. for an Fm antenna. Has anyone tried this?
Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880
Post edited by MSALLA on
Yep. should work great as long as you don't have an FM trap in your distribution system.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
I have never heard of that. That would be kind-of cool. However, FM antennas are really cheap. And since FM is a pretty short wave, you could jimi-rig just about anything to pick-up the signal, thus the cable. But good idea though!
I should clarify- a bunch of cable companies rebroadcast FM stations on their cable lines. So it's not acting as an antenna per say, but kinda like the local TV stations are put out on CATV. So, if your cable company does this, you'll get a badass signal- if they don't your house wiring will act as the antenna.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
I have tried it with poor results.
I don't know if it was my cable company or what but I had better luck with an antenna.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking
