Polk SDA 1B
Jockos
Jockos Posts: 310
edited October 2006 in Speakers
Someone here in the island's is selling SDA 1B's for $500. Is this a fair price? Exactly what do they look like how big and how many drivers. If anyone has any pics please post them.
Thanks Jockos
Post edited by Jockos on
  • ohskigod
    ohskigod Posts: 6,502
    edited October 2006
    thats the high end of fair in my eyes, they better be in good shape for that price though. it will have 2 tweeters (one on top of the other) with four 6 1/2" midbass drivers underneath, then a 12" passive radiator beneath the midbass drivers. also make sure there is an interconnect (the wire that runs between the speakers for the sda effect, for that price, it had better be there!)
    I doubt he has them, but just to note.....if he has the upgraded silk tweets inplace of the original sl2000's, that makes that price more than fair. the tweets will be black instead of silver.
    if the speaks look a little rough, try to talk him down a little. they are definitly a speaker worth owning, and I miss mine. make sure you have a common ground amp to drive them though
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • Jockos
    Jockos Posts: 310
    edited October 2006
    Is the adcom GFA 5500 common ground?
  • Jockos
    Jockos Posts: 310
    edited October 2006
    Checked out the speaker today. The cabinets are pretty good except 1 corner on the lower right rear is dinged. Also the pedestal on that same speaker has the vinyl veneer dinged on 3 corners. All the drivers look good. The foam edge on the right passive radiator looks like the glue came alittle undone on a small portion of the edge. Not sure of the construction of that driver but is there another material behind the foam; and the foam is glued to the surface? He has the cable and the grills are perfect. What would be a fair price? Also are these superior to the LSI 15's or just different sounding?
    Thanks Jockos
  • ohskigod
    edited October 2006
    I would definitly stay with the 500 bucks is the high side of normal opinion, but still fair none the less. If I really wanted to try SDA and never did, I might very well pay it.
    the Adcom common ground? I'm pretty sure it is, but send an email to adcom just to be safe. some others here might know, so ask maybe in the electronics section.
    better than the LSi 15? that will trigger a mad debate, while I like the LSi15 better (hence why I still own it, and not the SDA 1B), there are MANY here that would disagree with me whole heartedly. I think you hit the nail on the head when you said different. I would say that, in your audio travels, you should experience both.
  • ohskigod
    edited October 2006
    p.s., dont worry about the passive radiator, its cosmetic and from what I can tell will not effect sound. use it as a bargaining chip perhaps? along with the dings in the cabinet
  • Jockos
    Jockos Posts: 310
    edited October 2006
  • bert26
    bert26 Posts: 320
    edited October 2006
    Hi Jockos -
    Bluebook on those is about $441, so to echo Lou, $500 is on the high side of fair - especially with the dings.
    The puckering on the passives should not make any sonic difference (again as Lou said). Mine have the same issue and it hasn't really bothered me a bit.
    Cheers!
    Chris
    HT Rig
    Polk SDA SRS 2.3tl - Anthem 2 SE
    Polk CSi5 - Adcom 555
    Polk Monitor 30 - HK DPR1005
    SVS PB12 ISD/2
    Denon DCD-1500II
    Sony SXRD 60"
    ShengYa CS-10
    Basement Rig
    Polk SDA SRS2
    Carver 1.5t
    Carver C2
    Technics SLD202
    Some Other Sony DVD/CDP
