presence speakers
Hi guys. Just wanted some input on speaker choice. As you guys know yamaha runs two extra speakers up front. My question is what type would you run, say a rti4 or fxi3. To me the fx would give a more wide open feel, but just wanted some other input. Im running a csi5, psw505, rti12, and all r15s for the surrounds soon to be rti6. Thanks
Post edited by Joshwhite on
Neither.
First, you gotta determine if presence speakers are necessary. The verdict is still out on that one. Google "presence speakers."
Your next upgrade should be your sub.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Thanks for the reply. to me they are nice to have. they give that " big room " feel. thanks again
That's cool. I've never had experience with the presence speakers on a Yammie. Do they get the full frequency range?
The presence speakers is Yamaha's attempt to bring home sony's SDDS that is a commercial sound field or effect that was never released publically,to me it's not really all that compared to a properly calibrated home theater setup because I have tried it and I was not impressed,but if you insist on using it then try to match your front and center speakers with the presence setup.....My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
Well what stinks is on the lower model recievers, you can only engage presence or surround rear, not both at a time.The rxz9 can since it has extra amps, in that case i think the presence can add a bit more to the overall sound stage. But back to my original question. Do you think a focused sound of a rti4,6 would be better than the a dispersed sound of a fxi? Keep those thoughts comin. Thanks.
If it helps, I saw a floor model pair of FXi5s on the clearance table at the Towson, MD. Tweeter the other day. They looked fine and had a $100 off pricetag. I'm fighting the urge to get them for myself, would appreciate the help..HT/music rig
Panasonic PX60U 50" plasma
Yamaha 5990 AVR
Onix SP3 tube amp
bunch of Outlaw 2200 monoblocks
DUAL SVS PB12+/2 subs :eek:
Denon 3910 DVD/SACD/DVD-A
DirecTV HR10-250 DVR
Onix Strata Mini mains
Mirage OM10 surrounds
Polk CSi5 center
Polk SC80 rear surrounds
Samsung BDP1000 blu-ray player
Bedroom rig
Jolida SJ302a tube amp
Denon 2910 universal player
Onix Ref 1 monitors
Velodyne minivee
