This multi-channel crap is confusing . . . what cable, how many, huh?
SolidSqual
Ok so I just bought my pioneer Elite DV-46AV, right. I plan on getting coax cables for the multi-channel analog, but in the meantime, I'm using a Toslink cable to deliver sound to my receiver. The problem is that I can't figure out why my Xbox using the same cable and CD delivers stereo to my L and R speakers as well as my sub, but the Pioneer does not. Anyone got any suggestions? I want stereo with the sub on. How can I make this possible?
Post edited by SolidSqual on
You have to go into your receiver and change the settings. Review the manual.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
