Do I need an amp?
KLD2246
KLD2246 Posts: 42
edited October 2006 in Electronics
I just bought a new home. The front room is 15' wide and 22' deep. I have the polk rti 10's, the cs5 center and the fxi5 for surrounds. My avr is the rxv 1400 from yamaha. He listened to it and thought it sounded good but feels I need more power. What exactly should I get to push the power. A new avr or just add an amp. If I add and amp, is it a pre amp or something like that? I dont know anything about this. I just want more power. If I need more power, anyone have a suggestion on what I should buy? Let me know and best regards. Scott.
RXV1400 Yamaha Receiver
Polk RTi10s front
Polk CSi5 center
Polk Fxi5 Rear
Polk PSW505 Sub
Denon 1600 DVD
Direct TV HDDVR
55" Mits HDTV
Post edited by KLD2246 on
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2006
    Welcome KLD. If your receiver has preamp outputs all you will need for more power is a separate amplifier. I always recommend getting 200wpc. Any speaker will come to life in every way with that much power. There is no chance of hurting your speakers either since your ears will give out before the speakers do.
    I also recommend getting a 5-7 channel amp to be done with upgraditis for a good while! Amp choices are numerous. Outlaw, Rotel, Parasound, Sunfire, Adcom, etc. will all do fine. Check Audiogon.com for used equipment since you will get more for your money!
    Also getting a 5-7 channel amp makes it easier to upgrade since all you will need to get another big upgrade would be a Prepro when you get tired of your receiver!
  • Disc Jockey
    Disc Jockey Posts: 1,013
    edited October 2006
    Need an amp? No you don't need one if your speakers are reproducing sounds. But one would make everything sound better.
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • dane_peterson
    dane_peterson Posts: 1,903
    edited October 2006
    EDIT: I'll make my own post for this. Sorry.
  • KLD2246
    KLD2246 Posts: 42
    edited October 2006
    What if I dont have preamp outputs?
    Polk RTi10s front
    Polk CSi5 center
    Polk Fxi5 Rear
    Polk PSW505 Sub
    Denon 1600 DVD
    Direct TV HDDVR
    55" Mits HDTV
  • cfrizz
    edited October 2006
    Then you will need a new receiver that has them.
  • danger boy
    danger boy Posts: 15,722
    edited October 2006
    if your recevier doesn't have pre amp outputs. then you're looking at a receiver + an amp to get better sound from your speakers.
    PolkFest 2012, who's going>?
  • KLD2246
    KLD2246 Posts: 42
    edited October 2006
    OK, a new received and an amp to get better sound. I have $1000 to spend on the receiver for now. What receiver. Denon seems to be the logical choice but sure would like some input. Thank you all.
    Polk RTi10s front
    Polk CSi5 center
    Polk Fxi5 Rear
    Polk PSW505 Sub
    Denon 1600 DVD
    Direct TV HDDVR
    55" Mits HDTV
  • danger boy
    edited October 2006
    lucky for you. your Yammi RX-V1400 does have preouts.
    see pic below. just to the left of the speaker connections.. so all you need now in an amp.
  • KLD2246
    KLD2246 Posts: 42
    edited October 2006
    danger boy, what a great bit of news. Now I have 1000 to spend on an amp. Anyone have suggestions. I learn real fast so please let me know. How exciting is that.....
    Polk RTi10s front
    Polk CSi5 center
    Polk Fxi5 Rear
    Polk PSW505 Sub
    Denon 1600 DVD
    Direct TV HDDVR
    55" Mits HDTV
  • cfrizz
    edited October 2006
    Al you RULE!!!
    KLD, here are some good choices.
  • KLD2246
    KLD2246 Posts: 42
    edited October 2006
    Last question. Am I looking for amps or pre amp? Thats it and I will begin to shop. thank you all.
    Polk RTi10s front
    Polk CSi5 center
    Polk Fxi5 Rear
    Polk PSW505 Sub
    Denon 1600 DVD
    Direct TV HDDVR
    55" Mits HDTV
  • danger boy
    edited October 2006
    you're looking for an amp.... your RX-V1400 then becomes the pre amp.
  • danger boy
    edited October 2006
    deleted because i'm special. :p
  • KLD2246
    KLD2246 Posts: 42
    edited October 2006
    Wow, that is news to me. OK, now when I am asked the question, I can answer with authority. Danger and all of you, thank you very much. I very much appreciate your time and your knowledge.
    Polk RTi10s front
    Polk CSi5 center
    Polk Fxi5 Rear
    Polk PSW505 Sub
    Denon 1600 DVD
    Direct TV HDDVR
    55" Mits HDTV
  • danger boy
    edited October 2006
    wow.. the Rotel RMB-1075 sold already.. that was hella fast.
  • KLD2246
    KLD2246 Posts: 42
    edited October 2006
  • ND13
    ND13 Posts: 7,601
    edited October 2006
    Grats!!
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • KLD2246
    KLD2246 Posts: 42
    edited October 2006
    I bought a mits 55' in hdtv back in 2003. Its nice but nothing like todays models. No dlp or hdmi. Question, does anyone know about calibrating a hdtv because to me, the picture is lousy compared to my other 50" samsung with dlp. I just want to get the 55 in to look better. I live in southern california so if you know about this type of stuff, let me know. I cannot afford to buy a new tv but if I can make the picture better, then why not.
    Polk RTi10s front
    Polk CSi5 center
    Polk Fxi5 Rear
    Polk PSW505 Sub
    Denon 1600 DVD
    Direct TV HDDVR
    55" Mits HDTV
  • danger boy
    edited October 2006
    KLD2246 wrote:
    I went ahead and bought the rotel rmb 1075. It fit into my budget. Danger, you were a great help. I will let you know how it works. Thanks again.
    Grassy ****... :p
    that's a nice amp... it will bring new life to your speakers..
    one more thang.. use decent quality RCA interconnects from your Yammie to the Rotel when it arrives. That will give you the sound, openness and soundstage that you may have been missing. :D
  • brijenjas
    brijenjas Posts: 311
    edited October 2006
    Find a "Digital Video Essentials" disc, or an "Avia" disc for calibrating your TV.
  • KLD2246
    KLD2246 Posts: 42
    edited October 2006
    danger boy wrote:
    Grassy ****... :p
    Yea baby. I did it. I cant wait for it to arrive. I will get good interconnects at frys this weekend. Thanks for all you have done.
    Polk RTi10s front
    Polk CSi5 center
    Polk Fxi5 Rear
    Polk PSW505 Sub
    Denon 1600 DVD
    Direct TV HDDVR
    55" Mits HDTV
  • Sherardp
    Sherardp Posts: 8,038
    edited October 2006
    nice amp, good find Danger Boy. Im thinking of going with a 5 channel amp myself, something in the 200w x 5 area.
  • Grimster74
    Grimster74 Posts: 2,577
    edited October 2006
    If your looking to get a brand new amp, try Outlaw Audio's 7125 amplifier for $1000. Many people have purchased this amp with roughly the same speaker setup you are using and have had great results. You can also get a B-stock model for $899 that comes with a full warranty.
    Here is a link for a new 7125:
    http://outlawaudio.com/products/7125.html
    Here is a link for a B-stock:
    http://www.outlawaudio.com/mofcart/bstock.html
    If you buy a b-stock unit, that leaves some extra dough for cables.
  • KLD2246
    KLD2246 Posts: 42
    edited October 2006
    danger boy wrote:
    Grassy ****... :p
    I got the amp, went home and played with it. I basically shook the house off the foundation. What a great amp and I am very happy. Thanks danger and all that assisted me in this decision.
    Polk RTi10s front
    Polk CSi5 center
    Polk Fxi5 Rear
    Polk PSW505 Sub
    Denon 1600 DVD
    Direct TV HDDVR
    55" Mits HDTV
  • cfrizz
    edited October 2006
    LOL!!! That's great! Enjoy!!!
  • danger boy
    edited October 2006
    YW!
    have fun... with your your reved up system. ;)
