Recommend a good receiver for Polk Lsi series?
G-force
G-force Posts: 82
edited October 2006 in Speakers
I'm helping a friend install a home theater. He is going with 4 Polk Lc60i ceiling speakers and a Lsic center channel. I've heard of powering issues with this line because of the 4 ohm impedance. Can anyone recommend a good receiver to power these speakers with? Thanks!
Post edited by G-force on
  • just_visiting
    just_visiting Posts: 40
    edited October 2006
    With the Lsi line you'll have to get a receiver like the Yamaha Z9 or something that can handle 4ohm. I would save up to get an external amp to power them. Do a search on the Lsi and you'll find lots of good info.
    Display: Sony XBR3 46"
    Pre/Pro: Marantz AV7005
    Amplifiers: Anthem MCA20 / Anthem MCA30
    CD: Pioneer Elite PD59 / Sony XA20ES / Denon 755AE
    DVD: Denon 3930CI
    BD: Pioneer Elite 05FD
    Sat: Bell TV 9241HD
    Game: Sony PS3 60GB
    Media Streamer: WDTV Live Hub
    Power Console: Panamax 5300PM
    Speakers: Paradigm Reference Studio v.3
    Subwoofer: SVS 16-46PC+
    Preamp: Parasound P3
    Amplifier: BAT VK60 Tube
    Sacd: Sony 777ES
    Power Console: Ultralink PGX-500
    Speakers: Paradigm Reference Studio 20 v.5
  • shack
    shack Posts: 11,154
    edited October 2006
    B&K and NAD as well. I would consider these or the three Zero mentioned before Yamaha, Pioneer or HK.
  • ohskigod
    ohskigod Posts: 6,502
    edited October 2006
    I would say an Outlaw 990 pre/pro and one of there amps (the 200 wpc one) should be considerred if it fits in the budget. but as there saying above, you want the beefiest of recievers for the LSi. They love the power and current.
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • McLoki
    McLoki Posts: 5,231
    edited October 2006
    Here is a good (and current) thread for you to check out....
    Michael
  • read-alot
    read-alot Posts: 812
    edited October 2006
    If he is like me and not comfortable with wife dealing with amps and pre-amps he should get a B&K receiver and not look back. They stand by their products and are in the upstate NY area. My wife is happy with hers and so am I.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • Monster Jam
    Monster Jam Posts: 919
    edited October 2006
    I run mine with HK (which I've hears others describe as neutral sounding). I'd like to step up to seperates, but thats a LONG way down the road. In any case, I've found that the HK and LSi set up doesn't quite give me the treble levels I'd like to get with the tonal setting halfway, so I've increased the treble about 25% to compensate. I'm hoping that when I do get seperates, I'll be able to find a "brighter" amp to marry to the subdued LSi.
    Do you hear that buzzing noise? :confused:
    heiney9 Posts: 25,221
    edited October 2006
    Just to thorw another choice in the hat.....Adcom makes a new killer A/V receiver with true measured output for all channels.
    http://www.adcom.com/prod/shopdisplayproducts.asp?hid=0&cid=37&prodid=1140&sid=3
  • MSALLA
    MSALLA Posts: 1,602
    edited October 2006
    I was at tweeter and the guy was running Lsi-9's off a Yamaha RX-V659 at high volume for a good amount of time. I don't know what would happen with all 5 speakers being driven at 4ohms or if sound would be nicer off a dedicated amp, but it sounded good and there was no clipping.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • dane_peterson
    dane_peterson Posts: 1,903
    edited October 2006
    "A chain is only as strong as its weakest link." If he's willing to spend the money on upper-level speakers, he needs to be ready to spend money on everything else necessary to make them sound like they should. I say separates.
  • cfrizz
    cfrizz Posts: 13,415
    edited October 2006
    Welcome to the club Dane! It's very refreshing to have a newbie come on who knows the worth & true related cost to his speakers!!!
  • MSALLA
    MSALLA Posts: 1,602
    edited October 2006
    I agree. However, if you are in a stuation when room is an issue ,both with speakers and for components, and need bookshelf speakers and no room for separates the Lsi-9's still sound better then any bookshelf for the money.
    They had the best bass out of all the bookshelfs I've herd.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    Harmony 880
  • chip1
    chip1 Posts: 14
    edited October 2006
    g-force
    i have the lsic center channel with the lsi 9's i'm using a bryston 4bsst for the two front channels and a b&k 200.3 for the center and rear surrounds the b&k 200.3 will push the center channel with ease. tell your friend to try out that amp there's one up for sale right now on audiogon.com look up multi channel amps.
