Polks RTi6 or FXi5 for surround spkrs
dixlon
dixlon Posts: 28
edited October 2006 in Speakers
I've almost completed my HT upgrade for my 14x14x30 room that extends to the kitchen. I will have a 5.1 setup starting with the Outlaw 7500 amp, Anthem AVM30 Prepro, SVS-PB12 Plus sub, Polk Audio RTi8 fronts, CSi5 center and either Polk Audio RTi6 or FXi5 for the surrounds. My question is which surround speaker (RTi6 or FXi5) will be more efficient for HT and music? Thanks for your help.:)
Post edited by dixlon on
  • dane_peterson
    dane_peterson Posts: 1,903
    edited October 2006
    For all-around audio clarity, I would recommend the RTi6s. I have them as my front L/R right now, and they're very impressive. I am, however, considering replacing my rear L/R RTi4s with fxi3s, as I use my HT primarily for movies. If you tend to use your system more for movies than music, you may better appreciate the enveloping sound of the FXs. But that's just my 2 cents.
  • izafar
    izafar Posts: 819
    edited October 2006
    If you need to mount the speaker on the wall then go with FXi5. If you can put your speakers on stands slightly behind your listening position and you can position them to aim at you listening position, then go with RTi6.
    -izafar
    Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano
