help wiring please
gizsmo0
gizsmo0 Posts: 5
edited October 2006 in Car Audio & Electronics
i have a kenwood 800w 4/3/2 channel to power 2 mmc6500 and 2 mmc5250 the amp will power 70w x 4 at 4ohms or 100w x 4 at 2ohms or 200w x 2 at 4ohms thi amp is 2ohm stable how should i wire for best results.thanks in advanced:D
Post edited by gizsmo0 on
  • MacLeod
    MacLeod Posts: 14,358
    edited October 2006
    first off you should really use punctuation because it really makes it hard to read your posts you wont be able to wire them at 2 ohms because you dont have enough speakers in order to get a 2 ohm load youd need to wire 2 speakers to the same channel just stick with the 4 ohm wiring and youll be gine 70 watts per channel will be good for those speakers best would be about 100 but 70 should do the trick also dont forget to set your gains right so you dont clip the amp and kill the speakers and youll probably want the rear gain turned down a little below the fronts so you are only adding rear fill and not pulling the stage to the rear as much
  • gizsmo0
    gizsmo0 Posts: 5
    edited October 2006
    sorry about the grammer,thanks for the help:D
