installing new sys
gizsmo0
i am a newbee so please dont be to hard on me:D i have a kenwood ddx7015 hu
with jl12w7 powered by rockford 8002 which pushes 800rms at 4ohms to a 750 rms 3ohm speaker with 1500watt max will that hurt the amp or the speaker? also it is recieving signal from sub preout on the hu.my other question is i just bought two momo6500 and two 5250 and was going to use a kenwood 800w 4/3/2 amp
which would send 70w rmsx4 to them. first will this be enough to power these. also i never wired crossovers any help or hints would be helpful.also do i bring the signal from the preout on the hu or just y the amps. thanks sorry so long
Post edited by gizsmo0 on
come on somebody:(
As long as you calibrate properly, you won't hurt your amp or your speakers. Are you putting all your mids (6500 5250) up front, or are you splitting them front and back? Personally, I wouldn't Y the amps, I'd run the Front signal to one set and the Rear signal to the other set.
thanks thats what i was leaning towards.
