LSi question...
Grimster74
Grimster74 Posts: 2,577
edited October 2006 in Speakers
Considering starting my purchase of my LSi setup but have a question. If you were going to purchase a LSi setup, brand new, what would you go with as far as your front speakers? Would you purchase 9's or 15's. Space is really not a concern with me do to having the room but I'm just curious why one likes bookshelfs compaired to floorstanders. I currently use a SVS PB12-Plus/2 subwoofer so the low end is covered.
Post edited by Grimster74 on
  • Ricardo
    Ricardo Posts: 10,634
    edited October 2006
    If you're only going to use it for HT, I would go with the 9's; If you plan to also use the fronts for 2 channel music, I would go with the 15's. Of course, if money is not an issue, get the 15's....you won't have to think on how to place them at the right height (stands, etc).
    SOPA
  • Joey_V
    Joey_V Posts: 8,603
    edited October 2006
    Money delta not an issue, 15s hands down. Money and space and positioning an issue, 9s.
    The difference is much more than just the bass (though the 15s outdo the 9s in extension and accuracy.... no hump), the difference lies in the midrange. There is the 9's midrange... and there is the 15's MIDRANGE.
    I dont think I can explain it better than by "caps locking" it.
    If you go music, go 15s.
  • Emlyn
    Emlyn Posts: 4,826
    edited October 2006
    I was happier with the LSi9's in my home, mainly because the bass of the LSi15's was uncontrollable in the room I had them, probably because of the downfiring power port on a wood floor in a room suspended over a garage. If the LSi15's are set up on a solid slab floor, I'd go with them. I also think the LSi15's look nicer.
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2006
    For your application, LSi15.
  • fireshoes
    fireshoes Posts: 3,167
    edited October 2006
  • Early B.
    Early B. Posts: 7,900
    edited October 2006
    Just looked at your system showcase. Hell, yeah -- 15's.
    Invite me over when you get them.
    "God grooves with tubes."
  • polkatese
    polkatese Posts: 6,767
    edited October 2006
    15, slam dunk!
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • malikarshad
    malikarshad Posts: 527
    edited October 2006
    I have almost similiar room like yours and I prefer Lsi15 over Lsi9. I use it both for music (2-ch) and HT and I'm very happy with it.
    Speakers=>Salk Soundscape 8, Soundscape Center,Surrounds-Dali Rubicon LCR, Lsi7
    PreAmp, Amp => Marantz AV8801, ATI 6007 amp, Oppo HA-1 DAC
    Source => Sonore MicroRendu, Oppo BDP-103, Mede8er 600XD, Dune HD Smart D1, Synology DS1813+(16TB)
    Sub - JTR Captivator S2 (Dual 18")
    Power - Furman IT-Ref20i on dedicated 30Amp circuit with Furutech GTX-R outlet
    Screen=> JVC RS-45 projector Da-Lite HP 133" 2.35
  • GATOR3000
    GATOR3000 Posts: 355
    edited October 2006
    I got mine Lsi15’s 3 weeks ago and still breaking them in. So far the SQ is awesome. Get the Lsi15’s for sure you get bigger soundstage with the towers as oppose to 9’s.
    Gator:) :)
    Theatre System 5.1
    Sumsung HP-S5053 plasma
    Receiver Denon AVR 3806 Pre/Pro
    Parasound HCA 1500A amp (front L/R)
    Parasound HCA 1000A amp (centre)
    B & K AV5000 amp (bi-amp + surround)
    Dynaco ST70 tube amp (Herbie HAL-O9)
    polkaudio Lsi15 (Cherry) 2-channel
    polkaudio Rti8 Front (Cherry)
    polkaudio Csi5 Centre
    polkaudio Rti6 Surround
    polkaudio PSW1000 Subwoofer (Cherry)
    Original A8T CD
    Pioneer DV-275 DVD Player
    MONSTER CABLE MP-HTS3500MKII Powercentre
  • unc2701
    unc2701 Posts: 3,587
    edited October 2006
    Depends on the room. If you've got standing wave problems, then bookshelves +subs are a better choice. Basically, you can put a subwoofer where ever you want, but the mains have to go at the front of the room and it's not too odd for them to be sitting in the best place to excite at least one of the room's modes.
    It takes having a bad room before you realize how much it can impact the sound of your overall system.
    Anyhow, assuming you've got a good room, then the 15's win my vote.
    Backburner:Krell KAV-300i
