do i actually need 2 amps?
rhocelle
rhocelle Posts: 2
i recently bought 2 pairs of the MMC650 speakers and the C400.4 4/3/2 channel amp. im planning on purchasing a 10" sub. do i need to have another amp to compensate for the power it will be using?
Post edited by rhocelle on
  • Schwingding
    Schwingding Posts: 363
    edited October 2006
    IF I understand you correctly, you have purchased a system and an amp to run the speakers you currently have. You are asking if you will need an additional amp to run the sub. If that is correct, the answer is "depends".
    If you purchase a passive sub, you will probably want a separate amp to power it, but won't need 2 channels to do it.
    If you do like most of us, you will buy a powered sub that has a self contained amp. In this case, no you will not need another amp.
    If I didn't understand your situation correctly, well then, I have no idea!
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • SKsolutions
    SKsolutions Posts: 1,820
    edited October 2006
    Better question: "Do I really need 2 posts?"
    -Ignorance is strength -
