Rolling Stones SACD's
dagame27
In particular "Let it Bleed" and "Beggars Banquet". I just got these in today and WOW!!! They sound amazing. The recordings sound very modern, and with the SDA's the soundstage is huge! Highly Recommended, check them out.
ChrisPreamp: Anthem Pre 2L (Jan-Phillips Green) Processor: Marantz SR7012 Amp: B&K 200.5Streaming: Bluesound Node 2IDAC: Eastern Electric Minimax Plus4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
Post edited by dagame27 on
Thanks for the heads up. Since I have gotten the better gear it has made my stones cd's unlistenable (especially Sticky Fingers). If this is a lot better it is worth picking up a SACD player to me alone. Oh I miss Sister Morphine.
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
The only catch is the later cd's starting with "Sticky Fingers" are not yet in SACD as they were produced under a different label. I am not sure if they have been remastered yet. check out www.sa-cd.net for more info. If you order them just make sure you get the Digipak by Abkco. They stopped printing the SACD's for remastered CD's only and many retailers get them mixed up.The general rule is if it is in a digipak then it is a SACD as long as it is produced by Abkco and not Virgin.ChrisPreamp: Anthem Pre 2L (Jan-Phillips Green) Processor: Marantz SR7012 Amp: B&K 200.5Streaming: Bluesound Node 2IDAC: Eastern Electric Minimax Plus4K Bluray: Panasonic UB820Mains: Von Schweikert VR2Center: Von Schweikert LCR15 Subs: 2 SVS Sb13 Ultra (HT Only) Analysis Plus Cables
Sticky Fingers sounds great on my set up.Political Correctness'.........defined
