kehoi
dholmes
dholmes Posts: 1,136
edited September 2006 in Electronics
Is the site Im looking for to manually adjust my rptv called kehoi? If so what is the site called? Cant find it! Has anyone used that site to adjust there rptv,was it difficult? thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
    billbillw Posts: 6,884
    http://www.keohi.com/keohihdtv/
    Lots of useful info, but be VERY careful when you are in the service menu. I know of a guy who severely screwed up his TV set not once, but twice! A service call was needed both times!
    I used some of the methods discussed at the Keohi site as well as the site run by Cheezemo (Steve Martin). I adjusted overscan, centered the image, optimized geometry, did a full convergence, and lowered my Rcut to get the color more natural. That's about the extent of what I felt comfortable doing.
    Is it difficult? Yes, plan on spending the better part of a day, alone, no interuptions. Getting interupted or rushed is what leads to bad screw ups!
    For rig details, see my profile. Nothing here anymore...
  • Lsi9
    Lsi9 Posts: 616
    I wouldnt want to risk it, the risk usually out weighs the benefits, unless youve succesfully done it before.
    I looked into adjusting service menus and decided not to mess with something that has the potential of giving you a major headache not to mention a
    wallet ache
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • dholmes
    Thanks, I have some skills in electronics but I dont know if Im that good with it. I just wanted to set the convergence better.
