weak dialogue
rbjax
rbjax Posts: 2
edited October 2006 in Forum Testing Area
I have a Polk rm6750 speaker package hooked up to a Sony 7.1 receiver. The sound is ok except for the dialogue. I have to turn the volumn up to an unconfortable level to hear dialogue on most tv shows. Would a better center speaker (with larger speakers) help? We sit about 10 - 12' back from the plasma which is mounted on the wall.
Post edited by rbjax on
  • PolkThug
    PolkThug Posts: 7,532
    edited September 2006
    Go into the setup menu of your Sony receiver and adjst the levels +/- as necessary for each channel.
  • rbjax
    rbjax Posts: 2
    Thanks, I tried that once but will give it another try.
  • chip1
    chip1 Posts: 14
    edited October 2006
    hey! rbjax
    are you using a spl meter to setup the speaker levels, also on some cable channels the audio dialogue is reduced by at least -4 to -5 db's i also have to crank up the volume on my system and like you i thought the same thing of purchasing a better center channel which i did but it cost me a fortune because with upgarding the center speaker i upgraded my reciever to seperate amps and pre/pro and i still have to take it up a couple of notches. so bigger doesn't awalys mean better.
