how does power amp affect sub amps
jabrax
I have decided to setup a sub using the speaker connections.
AV receiver has preouts and A/B front connections for the fronts.
Currently, I have a power amp connected to the Preouts driving the fronts and the sub connected to the "A" front on the AVR.
Question? - What affect would wiring the subs to the power amp have on the woofer amp? Sub has only an 80watt amp i think. Would the sub ignore the 200 watts generated by the power amp.
Assumption is that I can wire the sub to the same power amp terminals as the fronts.
TV...............Hitachi 42hdS52a plasma (sexy one with the swival)
Pre/Processor - Emotiva MMC
Seven Ch AMP - Emotiva LPA
Fronts - Tyler Acoustics 7U's
Center - Polk LSIC
Sub - DSWPRO600
DAC - Music Hall 25.3CD - Marantz cc4001
Blue Ray - PS3
Speaker cables - Audioquest cv4 dbs
Interconnects - MIT AVT1's
Power Filter....Monster HTS 3500 MKII
Center - Polk LSIC
Sub - DSWPRO600
Blue Ray - PS3
Post edited by jabrax on
Jab, lets again start off with a little discussion of terminology: if as you say the sub is currently connected to the A speaker terminals of your 757, then that's already a speaker-level, rather than line-level, connection. If you mean that you're proposing to instead wire the sub to your separate power amp, there's no advantage in doing that. The input impedance at the speaker-level inputs of your sub is in the tens of thousands of ohms. When the impedance is that high essentially zero power gets through, just the music signal information. The internal amplifier in the sub remains entirely responsible for powering it; the power of the receiver or separate amplifier connected to the sub is irrelevant.
Thx again John,
just the information I was looking forTV...............Hitachi 42hdS52a plasma (sexy one with the swival)
Center - Polk LSIC
Sub - DSWPRO600
Blue Ray - PS3
