Subwoofer match to Bookshelf
I need a small subwoofer and satelites for my small Teac amplifier. I was thinking about getting the PSW202 and attaching 2 M10's as satelites for a simple stereo left and right channel setup. Would anyone care to comment if this is a good speaker match or not?
Thanks.
Thanks.
Post edited by ksapeta on
This would be fine for a simple system. Are there better? Yes, but there is notheing wrong with the components you are considering.Tschüss
Zach -
Thanks. My Teac Amplifier is the A-H500 rated 50 watts RMS at 50 OHMs. It is currently driving Niles in-wall speakers and in-wall subwoffer. I was going to add a speaker selecter switch and attach the subwoofer with the two satelites attached. Do you think there is enough power to drive all speakers at once? Is it safe?
If the speaker selector has an impedance compensation, yes - it will be fine.
If not, get a second amp, and go to town with y-splitters as needed.
Cheers,
RussCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
