X-Box Live
criverajr
criverajr Posts: 1,675
edited October 2006 in Video Games
Polksters,
My nephew wants to play his X-Box 360, live. What do I have to do to get this to happen, let me here from the experts. I have no clue.
CRj
Post edited by criverajr on
  • Demiurge
    Demiurge Posts: 10,874
    edited September 2006
    criverajr wrote:
    Polksters,
    CRj
    Go to a place that sells the XBox 360s, and buy the year long subscription card. Make sure you have an ethernet connection going to the back of the 360 (It's the same as the one in your PC). He'll have to pick a user name, and then enter the activation code on the card. Then you can go from there.
    If you're savy, you don't even have to go to the store. You can just purchase the subscription directly from Microsoft through your 360.
  • tommyboy
    tommyboy Posts: 1,414
    do you still need to buy a wireless adaptor for the the 360 or does it already come built in?
    if it doesn't, you also need to purchase a router and a wireless adaptor. Just make sure you don't buy linksys, mine always just disconnects for no reason.
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Dvd/Cd: Samsung HD upconverter (for now)
    TV: 50" Sammy Plasma
    game hardware: 360 and gcn.
    Gamertag: kovster27
  • polkatese
    polkatese Posts: 6,767
    One small recommendation on the wireless adapter, the one that was designed and build for it works the best for me. It connects easily, always on, never had problem. Before I tried a couple off the shelf USB-based wireless adapter, too much connection problem. It is a bit pricier, but it fits nicely.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • Shizelbs
    Shizelbs Posts: 7,433
    Demi hit the nail on the head.
  • punk-roc
    punk-roc Posts: 1,150
    +1 for Demi's statement... =)
    2-Channel - So far...
    Pre: Dodd ELP
    DAC: W4S-Dac2
    Source(s): Computer and Denon 2910
    Amp: Parasound HCA-1200II
    Speakers: LSi9s - Vr3 Fortress Mod
  • wingnut4772
    wingnut4772 Posts: 7,519
    Just beware...I used to have XBox live and I discontinued it because I grew weary of listening to a bunch of potty mouthed 13 year olds.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Sherardp
    Sherardp Posts: 8,038
    +1 with wingnut, there are always allot of profanity going on, racists slurs and more going on in there. If any of you play Call of Duty 2, look for NWA Boy Boy. I look forward to the challenge.
  • mrbigbluelight
    mrbigbluelight Posts: 9,874
    .....but you can put up with some of the hardheads on here ?
    :o
    Ditto on getting the Microsoft wireless for the 360. Some of the hoops that the non-MS wireless manufacturers make you jump through would make an IT pro cry.
    ......I know they cry easily, but still.......stick with the MS wireless.
  • landry_p2000
    landry_p2000 Posts: 1,313
    edited October 2006
    I have road runner upstairs, and my tv is downstairs, will I need only to buy a wireless adapter for my connection to xbox live?
    Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
    Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
  • Demiurge
    edited October 2006
    If you have a hard wired router, you'll need to run a cable with an Ethernet connection from your router to the back of your XBox.
    If you have a wireless router, you'll need to get the wireless adapter that you were inquiring about:
    It's like 90 bucks.....
  • landry_p2000
    edited October 2006
    Thanks Demi. I need to find out if I have a wireless router or not. I think its just the basic modem from comcast cable. Can I buy a longer ethernet cable? (Maybe about 50 ft.):confused:
  • Demiurge
    edited October 2006
    Yeah, you just need to buy a longer cable. Do you have a cable running into the back of your PC? If so, you're hard wired (no wireless), and you just need to get the same thing for the XBox (at the appropriate length, of course).
  • Shizelbs
    edited October 2006
    If all you have is the modem, you are going to need to get either a wired router or wireless router, unless the modem itself has more than one cat-5 outlet (which it likely doesn't). So, if you want both your xbox and your computer connected at the same time, you probably will need to also get a router.
  • Demiurge
    edited October 2006
    The **** is right, I forgot that not everyone has a router. :o
  • Shizelbs
    edited October 2006
    lol, "The ****"
  • punk-roc
    edited October 2006
    short for "The ****" for brains? I'm hilarious...
    Jason
    Pre: Dodd ELP
    DAC: W4S-Dac2
  • Demiurge
    edited October 2006
    Shizelbs wrote:
    lol, "The ****"
    :D :eek:
  • landry_p2000
    edited October 2006
    Thanks alot guys. I looked at the modem last night, and I am going to need a wireless router, the Xbox 360 wireless adapter, and the Xbox gold package. I just spent about $400 clams on the system, and a few bucks extra on an extra controller, also a few games. Man, the "Live" may be a few more weeks in the making. I may have to grovel a little to spend that extra.;) I think I am going the wireless route. I came up with about a $200 price range for every thing. Once again thanks for everything. I am Mr. Green Jeans when it comes to some things.
  • Demiurge
    edited October 2006
    Eh, don't worry, I still won't go wireless myself yet because of security issues.
  • Shizelbs
    edited October 2006
    Xbox live is easily worth that price of admission. It makes your experience much, much better.
