Ok any graphix guru's to help me make a custom sticker?
faster100
faster100 Posts: 6,124
edited September 2006 in DIY, Mods & Tweaks
Ya all know about the computer badge craze, athlon inside, custom this or that inside on a 1" x 1" dome sticker/
well im done with my tube amp case and wanted a custom "tubes inside" sticker made.. if someone can follow these guidelines below and make me something, i'll pay ya for it..
here is from the seller on e-bay that makes em custom...
We would be more than happy to do a custom Krystil Dome badge for you. We no longer offer any kind of design services for Krystil Dome badges and you will need to provide the artwork yourself. We do request that the artwork be created at 2in x 2in, 600dpi (1200 X 1200 pixels) and in CMYK color mode not RGB. We prefer the graphic in native format if possible (the default save format of the program the graphic is developed in e.g. Adobe Photoshop default saves as .PSD format) If you can develop your graphic using Adobe Illustrator, That would be ideal since Illustrator uses and saves in vector format which allows for the greatest resolution and resizability. We also request that you leave enough of the background to make a bleed area ( an area that goes off the edge of the sticker to assure no gaps around the edges). On a 2in x 2in layout there should be 1/2in between the parts of the image you are concerned with having on the sticker and the edge of the layout itself on all sides.
We can not use thumbnail images, small images, small images that have been enlarged to try to meet the 2in x 2in, 600dpi (1200 X 1200 pixels) requirement or low resolution web images, so please do not send them. If you would like to submit artwork that does fits the above profile, it can be sent to
Thanks for any and all help..
I want a throw off from the Intel inside... only i want a "tubes inside" sticker made
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Post edited by faster100 on
  • Vanhool
    Vanhool Posts: 58
    I can do that, however, i have no spare time so, if your patient i can work on it. If you want me to try them send me a pm with what you want.
    Van
    {HT, in the works}
    Polk-M10
    MTX-SW2
    Pioneer-VSX-516-k
  • faster100
    I'm in no big hurry.. Thanks alot i'll pm ya
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • dudeinaroom
    dudeinaroom Posts: 3,609
    I can do it also. Just let me know exactly what you want.
  • faster100
    awesome, i'll pm ya
    But depending on what level of experience you guys have/. I have none,
    I want the "intel inside" type logo or idea... But i want it to say Tubes inside.. that simple.. but with the guild lines above.. stated by the seller... Thanks alot again
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • dudeinaroom
    something like that?
  • dudeinaroom
    I have it as a .psd, pm me
  • dudeinaroom
    oh yeah, give me colors
  • faster100
    that's great!! is that the size they said it needs to be? just checking as i know little about it at all..
    I like those colors
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    well Dudeinaroom hooked me up with a graphic and i submitted it to be printed.. here is a copy of the sticker in dome format from them, they sent me a copy... This will go on the front panel of my tube amp..
    Thanks again for the help
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • phoneisbusy
    phoneisbusy Posts: 867
    Cool! Would it be cheaper if you ordered a couple of stickers? It might be fun to stick one of them on my headamp...
    regards
    Dave
    Time is the best teacher. Unfortunately it kills all its students.
  • madmax
    madmax Posts: 12,434
    regards
    Dave
    Yea, I want some too! :)
    madmax
    Vinyl, the final frontier...
  • faster100
    Hey, then mine wont be unique!! LOL you guys can have another color though.. I paid $4.25 for one, the price go's slightly lower over 5.. if someone wants some let me know and send me some dough and i'll hook it up.. that includes shipping, or i'll pm the companies address to ya
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • madmax
    I'll wait until you get yours. :)
    madmax
