Couple of amplifier questions
Schwingding
Schwingding Posts: 363
edited September 2006 in Electronics
I'm stymied by several things in the amplifier arena and would appreciate some clarification. As a relative newbie I'm not ashamed to admit I don't know nor afraid to ask. Your help as always is appreciated.
First, I can't seem to get a good description of what the different classes of amplifier are about. What makes an A? B? G? etc..
2nd, seems that most standard amps are all about power. Everyone wants lots of wattage. But then it seems that most of what are considered the "best" amps - tube amps (far as I know), all seem to have comparatively low wattage.
This conflicts with the info in my head that anything above a standard dialogue level needs watts (slight increase in volume = double the power requirements), yet most of the tube type amps seem to have far less watts available than less costly amps. ????
Thanks for helping with my education. (No, I am not considering tube amps, just curious to know)
HT/music rig
Panasonic PX60U 50" plasma
Yamaha 5990 AVR
Onix SP3 tube amp
bunch of Outlaw 2200 monoblocks
DUAL SVS PB12+/2 subs :eek:
Denon 3910 DVD/SACD/DVD-A
DirecTV HR10-250 DVR
Onix Strata Mini mains
Mirage OM10 surrounds
Polk CSi5 center
Polk SC80 rear surrounds
Samsung BDP1000 blu-ray player
Bedroom rig
Jolida SJ302a tube amp
Denon 2910 universal player
Onix Ref 1 monitors
Velodyne minivee
Post edited by Schwingding on
  • bert26
    bert26 Posts: 320
    Hi - try this site for a brief run down on amp classes. I am not certain that it is completely accurate as I am new to these things myself. At least it is a leaping off point.
    As far as the wattage thing goes, I believe it has something to do with current. You need more watts with lower current and visa versa - again don't quote me.
    I am looking forward to learning from this thread as well.
    There are several threads in here as well that review what you are looking for - try using the search function.
    Good luck!
    Chris
    HT Rig
    Polk SDA SRS 2.3tl - Anthem 2 SE
    Polk CSi5 - Adcom 555
    Polk Monitor 30 - HK DPR1005
    SVS PB12 ISD/2
    Denon DCD-1500II
    Sony SXRD 60"
    ShengYa CS-10
    Basement Rig
    Polk SDA SRS2
    Carver 1.5t
    Carver C2
    Technics SLD202
    Some Other Sony DVD/CDP
  • Schwingding
    Hey thanks. That link was a really good read. I need to start referring to the Wiki more often. I always forget about its existence.
    HT/music rig
    Yamaha 5990 AVR
    Onix SP3 tube amp
    Polk CSi5 center
    Bedroom rig
    Onix Ref 1 monitors
    Velodyne minivee
  • univera
    univera Posts: 848
    One thing I've learned from this site (among many) is that most of the time, even at high volumes, your amp isn't really isn't using much wattage. Higher watts give you the ability to handle dynamic/explosive/large DB rises more efficiently and fluidly and allow you to play music louder and cleaner before distorting. These dynamic passages will be faster and have more life. The less your speakers have to "strain" to reproduce the sound, the more transparent and natural it becomes. Hope I am accurate.
    UNIVERA
    Historic Charleston SC
    2 Channel:
    SDA-SRS's RDO tweets
    Biamped Anthem 2 SE's w/1970's NOS Siemens CCA's
    Anthem Pre 2L w/E.harmonix platinum matched 6H23's
    CDP- NAD C 542
    HT setup:
    AVR: NAD T 773
    Rears: Polk LC80i
    DVD: Toshiba 3109 dual tray
    Subs: Velodyne and M&K
    T.V.: Sony KDL-52XBR4 w/Vans Evers Clean Line Jr.
    Conditioner: Panamax M5100EX
    Master Bedroom Sony 40KDL-XBR3
    "I love it when a plan comes together." Hannibal Smith, The A-Team
    mhardy6647 Posts: 35,035
    If one runs inefficient speakers, one needs lotsa "RMS" (continuous) watts in one's pocket. But there is another way, Grasshopper...
    www.bottlehead.com
    www.welbornelabs.com
    (note: there are many other fine low power amps & high sensitivity speakers... get out there and explore them!)
