Just purchased! new oz audio sub!!!
joeaudio26
I just purchased a new oz audio 12 vecter series sub its 350 rms and peaks out at 700 im pushing it with a jbl 1 channel amp . The amps specs are 300 rms at 2 ohms 400 peak at 2 ohms so im definetly giving it the proper power its cea 2006 compliant so u know what your getting .:D
Whatsoever thy handfindeth to do, do it with thy might; for there is nor work, nor device, nor knowledge, nor wisdom, in the grave, whither thou goest.
Post edited by joeaudio26 on
Nice choice in subs. I had an older version of the Vector series and it was nice. I later upgraded to a Oz Power Matrix 15. This subs was a BEAST!2004 IASCA Spring Break Nationals Champion - Amateur Street
2003 IASCA World Finals Runner Up - Amateur Street
Certified IASCA Judge -
beef316 wrote:Nice choice in subs. I had an older version of the Vector series and it was nice. I later upgraded to a Oz Power Matrix 15. This subs was a BEAST!
lucky u i couldn't spend 350$ on the matrix but if i had the cash i would do the same.:)Whatsoever thy handfindeth to do, do it with thy might; for there is nor work, nor device, nor knowledge, nor wisdom, in the grave, whither thou goest.
