Dual SVS SB12-Plus...
Grimster74
Grimster74 Posts: 2,577
edited September 2006 in Speakers
This is just a curosity question, how do you guys think dual SB12-Plus subwoofers would hold there wait against a single PB12-Plus subwoofer? I'm pretty sure I already know the answer but I would be curious to see what you guys have to say.
Post edited by Grimster74 on
  • wingnut4772
    wingnut4772 Posts: 7,519
    SVSOUND wrote:
    So, if you can "afford" one of our bigger subs... from the standpoint of the larger floor space requirement ... by all means, consider something of a similar price class, such as the PB12-Plus, or even one that's less expensive like the (large) new PB12-NSD.
    If you need room rattling power, the ultimate depth, AND want a small footprint too? Then our exclusive space-saving Powered Cylinder subs should be on your short list to evaluate.
    Even SVS thinks the the PB12/PLus if you have the space. Can you swing the Ultra? Even better.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
