What to do? Set up to big for room! I think...
So for the last month I've ignored my ht set up. It's not exactly the sound I'de like and and i think I've figured it out. I have a HK avr 435, rti4's for mains, csi3 center, svs pb10 sub and some small klh's for the rears. I was planning on getting some rti8's as mains and moving the 4's back. I think that might be a bit much I noticed that the sound is alright at my listening level but as soon as I turn the volume up high the sound gets fantastic but the volume is higher than I'de like listening volume -40db and the great sound is at -22db. I think my room is to small for this set up. My room is 11x12ft with 7ft tall ceiling going into an 8ft cieling. Anything I can do to help clear the sound up without raising to high volume? and will the rti8's make this worse or better? Thanks.
Post edited by Jer_ry on
You might try getting a separate amplifier and hook it up to the pre outs on the HK 9 assuming it has them). Anything from Outlaw Audio would do the trick.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Before you do anything, buy anything, or even adjust anything.....
http://www.audiophilia.com/hardware/spl.htm -
I agree with Frank that calibrating each speaker with an SPL meter is essential to getting balanced sound at all volume levels. I would also suggest that you pick up a DVD of Avia or Video Essentials to help you understand what you are seeing and hearing from your system. These discs can help you get your TV calibrated properly for the best picture too.
http://www.amazon.com/AVIA-Guide-Home-Theater/dp/630551982X/sr=8-1/qid=1159119151/ref=pd_bbs_1/002-0077855-5396878?ie=UTF8&s=dvd
Lots of Polkies have systems in bedrooms and living rooms around the size of your room and get good sound out of their system when putting some effort into proper setup. Be glad you room isn't so large that it takes 5-7 channels of 300 watts just to fill!HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Yeah, once youy get it calibrated, I'd still say go for the 8's with 4's in the back OR put Rti6's up front.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Personally, I'd go for the 8's. But that's just because I prefer floor-standing vs bookshelf for fronts.Don't forget to look at My Home Theater
Receiver - Onkyo TX-SR503
Fronts - Polk Audio Monitor 40
Center - Polk Audio CS1
Surrounds - Paradigm Cinema ADP
Subwoofer - Velodyne VRP-1200 -
one of 2 things, the HK doesnt reach it's sweet spot until you get the volume up there or the same for the speakers.. I have small rt25i's and they need a higher volume to get the bass and sound i like.. you wont get louder and detailed sound IMO with small bookshelves or unless you have more power.. Get either the rti6 or 8's and you will be more impressed with your HK then you are now.. more impact and at less volume,MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
The Rti6s up front and Rti4s for the surround would do the trick for the size of your listening area and ceiling heights. Rti6s are awesome speakers and need power. I would suggest giving them at least 100 wpc external amp. More powerful amp will help to fill your room with lover volume settings. Also, you would improve SQ of your system.
Rock on.
GatorTheatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre
