recycled SVS drivers
sucks2beme
Has anyone here tried using the older SVS 12" drivers in car applications?
I've got one after upgrading my SVS home sub to the new improved driver.
It looks to be built quite well. I assume it's just a standard 4 ohm driver
and can be used anywhere a standard 12" is used.
Contact SVS - they won't give you all the values to plug into WinISD, but they will advise you what you will need for porting, internal volume, amp size, etc.
