Big Phat Band - Latest Release
polkatese
Some of you know that this Big Band is THE bomb when it comes to Brass-erie...this is even better: it comes with both CD AND DVD Dolby Digital 5.1 for a merely $12.99 from Amazon.
Check out Dianne Reeves "Too Close To Comfort", great album and arrangement!
http://www.amazon.com/gp/product/B000FIHJJ2/002-5789247-8498427?ie=UTF8
no affil., I am just so jazz-up with every Goodwin's Album.
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Post edited by polkatese on
Yep, big band is where its at. I have the first SACD of BFB and its awesome. I'll give this a try next time I order something.
polkatese wrote:Some of you know that this Big Band is THE bomb when it comes to Brass-erie...this is even better: it comes with both CD AND DVD Dolby Digital 5.1 for a merely $12.99 from Amazon.
This band sounds very interesting. Can anyone give a review of the
DD 5:1 mix? Does it use the rear channels aggressively?
MikeFronts: SDA1C's
Rears: SDA2's
Center:CS400i
Sub: PSW505 -
Yes, Mike. They utilized surround channels effectively. Assuming that you have calibrated your SPL level for all channels, I'll give you the assurance that you will notice a distinct difference Whether you will like it or not, I can't say, but if you like to hear arrangements in which the horn section is very active, this the album to cherish.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
